I have a simple question regarding a very simple formula
I am embarrased to even ask, but I figure I would rather be laughed at and take it, then not learn something.
The question is very simple:
All I want to do is be able to figure out what voltage I will get when resistor(s) X is in series. I have looked on the net to find calculators that give watts, current, etc. but I would like to know voltages for starters.
Example circuit:
··············· 10k
5v <
| GND = how many volts?
Example circuit:
··············· 10k
5v <
·1+1=10
In series with what? As shown in your post, you have 5V, there is no "formula".
If you're talking about this:
··················7k··········· 3k
5v <
^^^----| Gnd
························?v
Then you first have the fine the total current (I = 5/10,000 = 0.5 mA)
Then find the Voltage drop accross one of the resistors (E= 0.5mA * 3,000 = 1.5V)
The basic formula is E=I*R (Volts = Amps x Resistance)
John R.
John R.
8 + 8 = 10
Example #1: +5V >---/\/\---< GND R In this case you will always "see" 5V across R Example #2: +5V >---/\/\---o---/\/\---< GND R1 | R2 o----------> Vout Here, Vout = Vsupply * (R2/(R1+R2)) OR Vout = I * R2, where I = Vsupply / (R1+R2+...+Rn) I personally like the second formula, because you can easily determine the voltage across any resistor in the chain once you determine the current. Suppose R1=3K and R2=2K I = +5V / 5K = 0.001 Amps = 1mA Vacross_R1 = I * R1 = 3V Vacross_R2 = I * R2 = 2V▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
Post Edited (SN96) : 1/10/2006 11:16:55 PM GMT
Rick
Greetings from Germany,
G
