translating from 2p to SX
I am trying to conver the listing for reading and writing to the 24lc128 EEPROM and have run into a (maybe for others a symple) problem.
The original listing uses "word" for varables to hold the address bytes.· I have tried using byte(2) but when I have to break it into two bytes for the I2Csend, I run into problems.· I need to have the lower byte and the upprer byte sent seperately.
listing attached
your help will be highly appreciated
Regards
Chet
listing attached
Regards
Chet
··Look at the example program in the help file for I2CSEND. It uses the 24lc16 which is basically the same part but smaller.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
"Ability may get you to the top, but it takes character to keep you there."
Post Edited (Bean (Hitt Consulting)) : 1/11/2006 12:51:28 PM GMT
Jon Williams
Regards
Chet
