I have found that the STAMP has trouble with decimal formatting at 9600 baud (bps).
The HELP for SERIN/SEROUT states that this is likely.
Anyway, I say this because I have downloaded the following program and verified my statement.
It would not work at 9600, but it works great at 4800 bps.
It is practically the same program that I first sent.· However, it is using SERIN 16 like you want.·
I have an LED on P0 and another on P1 that turn on to verify the outputs·in accordance with·valid/desired SERIN,·they confirm LEFTVAL and RIGHTVAL correctness.
I send data·to the STAMP using the first format, that is,·with the parentheses and the comma in·the middle: (###,###).
My Conclusion -- I think that you need to slow down your Linux or whatever is sending data to the STAMP to 4800 bps.· Hopefully this will not be·impossible.
PJ, I have had SERINs not work when I looked for an early termination char (the \L {\E} )- but *did* work when I omitted the specified end character. (At certain speeds, namely 9600.) Just confirming your statements.
Ryan
Ryan Clarke
Parallax Tech Support
I have only 1 serial port in my PC sharing both modem Internet Connection and Communication with BoeBot. So, each time I want to test a program I have to disconnect.
It's really irritating! If I use a usb-to-serial adapter do U think I will solve this problem? I mean, the Basic Stamp will be successfully recognised by the program editor?
My Conclusion --
Try it, you'll like it.
' {$STAMP BS2} ' {$PBASIC 2.5} ' {$PORT COM1} LEFTVAL VAR Word RIGHTVAL VAR Word Prelims: DIRS = $0F 'MSB INs, LSB OUTs OUTL = %00000000 'preset OUTs INH = %00000000 LEFTVAL = 0 RIGHTVAL = 0 GetData: SERIN 16, 16572,[noparse][[/noparse]WAIT("("),DEC LEFTVAL,DEC RIGHTVAL] IF LEFTVAL = 100 THEN GOSUB LED1ON IF RIGHTVAL = 200 THEN GOSUB LED2ON PAUSE 5000 GOTO LEDSOFF LED1ON: OUT0 = 1 RETURN LED2ON: OUT1 = 1 RETURN LEDSOFF: OUTL = %00000000 LEFTVAL = 0 RIGHTVAL = 0 GOTO GetData... and That's The Way It Is.
Post Edited (PJ Allen) : 1/10/2006 11:12:05 PM GMT
Could you please remind me what the proper number for 4800 8n1 connection to write in my code? I mean like 16468 is for 9600 8n1. What s for 4800 8n1?
John.
Ryan
Ryan Clarke
RClarke@Parallax.com
John.
[noparse][[/noparse]I'll try your code now...]
Post Edited (PJ Allen) : 1/10/2006 11:40:25 PM GMT
