I have a simple question regarding a very simple formula — Parallax Forums
SN96SN96 Posts: 318
edited 2006-01-12 02:21 in General Discussion
I am embarrased to even ask, but I figure I would rather be laughed at and take it, then not learn something.
The question is very simple:
All I want to do is be able to figure out what voltage I will get when resistor(s) X is in series. I have looked on the net to find calculators that give watts, current, etc. but I would like to know voltages for starters.
Example circuit:
··············· 10k
5v <
| GND = how many volts?
    edited 2006-01-10 21:45
    Hmm Im slightly confused, the voltage drop across a single resistor will always be equal to the supply voltage. If you ware talking about multiple resistors and measuring the voltage between two of the resistors, the voltage will be equal to the supply voltage times the fraction of the resistance betwwn the tap point and ground divided by the total resistance. So for the simple example of two resistors configured as 5V---4.7kΩ---3.3kΩ---GND, measuring the voltage between the resistors wrt GND would be 5V x (3.3kΩ/8k&#937[noparse];)[/noparse] = 1.65V.
    ·1+1=10
  • John R.John R. Posts: 1,376
    edited 2006-01-10 21:49
    Mike;
    In series with what? As shown in your post, you have 5V, there is no "formula".
    If you're talking about this:
    ··················7k··········· 3k
    5v <
    ^^^----| Gnd
    ························?v
    Then you first have the fine the total current (I = 5/10,000 = 0.5 mA)
    Then find the Voltage drop accross one of the resistors (E= 0.5mA * 3,000 = 1.5V)
    The basic formula is E=I*R (Volts = Amps x Resistance)
    John R.
    John R.
    8 + 8 = 10
    edited 2006-01-10 22:02
    With the example that you provided, you will always see 5V across the resistor.
    Example #1:
    +5V >---/\/\---< GND
             R
    In this case you will always "see" 5V across R
    Example #2:
    +5V >---/\/\---o---/\/\---< GND
             R1    |     R2
                   o----------> Vout
    Here,
    Vout = Vsupply * (R2/(R1+R2))
    OR
    Vout = I * R2, where I = Vsupply / (R1+R2+...+Rn)
    I personally like the second formula, because you can
    easily determine the voltage across any resistor in the
    chain once you determine the current.
    Suppose R1=3K and R2=2K
    I = +5V / 5K = 0.001 Amps = 1mA
    Vacross_R1 = I * R1 = 3V
    Vacross_R2 = I * R2 = 2V
    Beau Schwabe
    IC Layout Engineer
  • SN96SN96 Posts: 318
    edited 2006-01-10 23:06
    Thnaks, I was going to include a second example showing two resistors in series with a tap between the two but figured the first example would get me somewhere.
    Post Edited (SN96) : 1/10/2006 11:16:55 PM GMT
  • rockin_rickrockin_rick Posts: 32
    edited 2006-01-11 22:36
    To help with further searching, these circuits are typically known as voltage dividers. Try searching for that and you may find a calculator...
    Rick
    edited 2006-01-11 22:56
    Well, I don't think they teach this at law schools, but all this is handled by Ohm's law (plus Mr. Kirchhoffs comments) smile.gif .
    Greetings from Germany,
    G
    G
    1161 x 599 - 60K
