Soldering SX48 SMT
william chan
Mr Bean,
I have good news for you.
Just now I successfully soldered 3 SX48s using solder paste injector and a conventional oven.
Here's how I got it after a few tries.
1. Inject a thin line of solder paste on top of each row of pads.
2. Use a small cut out sponge to spread the paste thinly over the pads. Make sure they are really thin. Remove excess with tissue.
3. Place and align the SX48 using a magnifying glass with light.
If the solder paste is thin enough, you should still be able to see about 50% of the pads. This will help you align. I also use longer pads.
4. Put a small length of solder on the board near the SX48, and place the board into the pre-heated oven set at 250 degree celsius.
5. When you notice the solder length melt into a ball, get ready. Give it another 10 seconds, then remove the board slowly by pliers.
If the solder paste is thin enough, it usually will not bridge. I didn't use any flux.
Of course the board should have solder mask to reduce the chances of a bridge.
Good luck.
Good luck.
Thanks I will give that try sometime.
I'm interested how is everyone else mounting the SX48 ?
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
"I hope the goonwave is not vaporware"
·1+1=10
Post Edited (Paul Baker) : 1/6/2006 3:16:48 PM GMT
When you say "Wave Solder", are you talking the commercial production board lines, or some type of "prototype" process.· I'm a hobbyist, familar with the production assembly line/wave machines.· Is there a wave soldering availalbe for small runs?
John R.
8 + 8 = 10
Ryan
Ryan Clarke
Parallax Tech Support
RClarke@Parallax.com
·1+1=10
I can do SOICs in my sleep, but was actually a little worried about the '48s pitch.
I'm also planning on trying the electric frying pan reflow (heard it's a bit easier/more controllable than the toaster oven).
-marc
I haven't tried the SX48 yet, but I managed to solder and SX28SS by tacking one corner, aligning the rest of the pins with the point of an xacto knife, then putting the tiniest drop of solder on the end of an iron and pushing it down the traces towards the pins. I do 2 pins at a time this way, and got really nice little slopes of solder running from the pins to the traces.
Whatever method you use, remember that flux is your friend.
I wonder if this wire is hot...
-marc
Flux will help remove those pesky solder bridges on the last legs of a row on a quad flat pack -
Ryan
Ryan Clarke
·1+1=10
Does it matter?
