SX_Key Debugging Session
Dear Sirs,
I am using a tutorial program from the the Gunther Book (Programming the Sx).
No problems most of the time and the progra runs OK.
But occasionally when I step through the programme the Debugger dissappears.
This also happens more frequently when I use walk (especially at the faster speeds)
Please note, this is an intermittant problem, it seems to happen only when I step
at a fast rate or when I use walk set at a fast rate (but some times at a slow rate too).
Running the programme works fine.
So it is not a problem with the programme (any way it is a simple one Tut03.src and this happens
with other programmes e.g Tut04 etc. too).
Also since the problem is only occasional, that implies that there is something wrong with the IDE.
Again the problem is:
····· The debugger dissappears on certain occasions after pressing Step a few times at fast rate
······ or when Walk mode is used, but not all the time.
Please let me know if this problem has been encountered before.
I am using Windows ME, Pentium III and SX_Key Rev F software ver 3.1 and the system is Pro Dev system.
I do not have the resonator connected, all switches and fuses are set correctly by the programme.
Thanks in advance
Samuel Mishal
Thanks in advance
Samuel Mishal
I think I have a solution, Thanks to Gunther's FAQ.
I set my Com Port FIFO to very low and now I have not been able
have the problem come back. So this seems to have been the solution.
BUT, would it not be better if the·Debugger reported a problem or an error message
rather than just dissapperaing of the desktop???????
Thanks Gunther, your book is great and so are your contributions in this forum.
The FAQ that helped me was :
SX-Key not found on COMx Error
Q: [font=Arial,Arial color=blue size=2]When I try to program an SX device with the SX-Key, the IDE reports an "SX-Key not found" Error", what is the reason for this? [/font]
[font=Arial,Arial size=2]The reply to this FAQ had the bit about the FIFO and I thought that sounds like it might be related[/font]
to my problem. And so I set the FIFo to "low". After this I now can step and walk as fast as I want without
the Debugger perfoming a vanishing act on me.
Thanks Gunther.
To Mr. PJMonty,
I am wondering what in the programming could cause the debugger window to just vanish
instead of causing an error message or just hanging even. I am glad it does not hang though!
Thanks all.
Samuel Mishal
[/font]
thanks for you kind words - I'm glad to learn that my writing sometimes really helps out of troubles
Concerning the disappearing Debugger window: As far as I can remember, former versions of the SX-Key IDE behaved like this when you have set focus (clicked on) another window. Which SK-Key IDE version are you using?
Greetings from Germany,
G
Not sure what's going on with the disappearing window. You're the first person I am aware of who has reported this problem. Since it seems to have been fixed by the FIFO settings, I'll file it under "mysterious circumstances" for now, but keep my open for it in the future.
Thanks, PeterM
I am using the latest and the best (hehehe). Rev. F with 3.1 IDE.
It is not a problem of loosing focus. It happens while I am stepping or walking, especially if I do it
at fast rates. When stepping using Alt-S it happens if I press Alt-S rapidly, with the mouse the same.
Since the FIFO resolves it it sounds to me like a bug with the IDE's serial comms routines.
But I am racking my tiny brains as to how a comms buffering problem could cause such a thing,
except it might be a buffer over-under flow and thus writing in un-allowed memory space and this is causing a
window close. I.E. the same old story when programming using C/C++ where pointers cause
memory overwrites etc.
I do not know if the IDE is programmed in C or not, but most other programming languages stop
this kind of thing.
Regards
Samuel
The IDE is written in Delphi, which is object oriented Pascal. I doubt is a buffer over or under flow since that would be more likely to cause an exception to be generated and the entire program to get shut down by Windows. In addition, there are no pointers used in the source code for the communications system in the IDE. You canuse pointers in Delphi, buit there's usually not a pressing reason to do so. I'll see if I can replicate your results here.
Thanks, PeterM
Interesting I did not know that Delphi is still being used. I use Borland C++ which has the Delphi windows library.
I had the serial comms FIFO set at Max when I was having the problem. Setting it at Low has resolved the problem.
So please note that when you are trying to replicate the problem, also I am using windows me.
I would be interested in what the problem is. I am still wondering what kind of error would cause
a window just to vanish. Oh, by the way, some times the whole debugger vanishes and somtimes just the main
window leaving the control panel there.
Any way, thanks for a great IDE and the SX_Key is great.
I have a wish list for the IDE:
Here is the wish list:
1-Like in the Stamp editor, can there be a Direcory tree
2-Can you add a Close-All option to close all open files at once
3-Can there be a Close button on the Tool Bar to close the current file
4-Can you add the ability to use a Template file when the editor opens a new file.
Thanks again for a great product and for the great support and PROFESSIONAL everything..........
Samuel Mishal
1 - Not familiar with the Stamp editor. Where are you thinking you need a directory tree? When you open files?
2 - It's already there. Take another look at the "File" menu and you'll see "Close All".
3 - Right click on the list of open files on the left of screen and there's a menu option to close the current file.
4 - It does use templates when you open a new file if you have templates in the "Templates" directory and the "Use templates if available" option is checked in the configuration dialog. You can only have one SX/B and one assembly template in the directory and they must have the names "Template.SRC" and "Template.SXB". If you are hoping to have more extensive template capability added, see this thread for more discussion about templates and the concept behind their implementation:
http://forums.parallax.com/showthread.php?p=560621
You may have to scroll up to see the start of the thread.
Thanks, PeterM
1 - I am talking about the Basic Stamp Editor (Parallax's)
···· I am enclosing an image that shows the IDE there and I have added pointers to the
···· kind of thing I am talking about.
···· The directory tree even allows you to move/copy/delete files between directories etc.
···· i.e. it is a fully functional explorer. This makes it much easier to manage files you are working on
··· and tidy up projects, templates, include files etc, etc.
··· The Basic Stamp Editor is quite convenient, if you are not familiar with it you should give it
··· a run, it is a very very good IDE.
2 -
3 -· Yes I saw that but it has to be done like this
···· a-click on the file to make it the highlighted one
···· b-right click on the file to bring the pop-up menu then choose close
··· it would be much more convenient to have an icon on the Toolbar
4 -
····· know of a good drug for dying brain cells
Anyway these are all nice "conveniences" to make a great product even greater.
Regards
Samuel
