SX/B IR Remote control revisited — Parallax Forums
RsadeikaRsadeika Posts: 3,877
edited 2005-12-30 21:45 in General Discussion
This is essentially a problem that I had talked about earlier. I have below some SX/B code for the SX28 Tech board and the SX52 proto board. This is in essence a derivitive of Jons SIRC code. I tried to make things as equal as possible for the two scenarios. Meaning, I set up a circuit so that I can hook up either the SX28 tech board or the SX52 proto board. Each board powers the circuit when it is hooked up.
I think I have narrowed the problem down to either·a quirk with the SX52 board or a quirk in the compiler when it deals with the particular piece of code in SX52 setting.
The specific piece of code is:
·do
··· pulsin IRpin, 0, temp1
· loop until temp1 > 216
When this segment is run on the SX28 Tech board, the code runs as expected. When I run this segment on the SX52 proto board, it hangs, or freezes if you will. For the SX52 proto board I played around with some values just to see what would happen. When I put in 'loop until temp1 > 0', there seemed to be a response, the LED came on. When I put in 'loop until temp1 < 216', the program liked that, the LED came on. In the SIRCS program, in order for it to work correctly the·code has to be 'loop until temp1·> 216'. There is something definetly wrong. My SX28 Tech board is doing just fine, and Jons SIRCS program works fine on the board.
Last week I was trying to replicate this in asm code, that is·when I started to run into some big problems. Just enough knowledge to get you into some really big trouble. So, now I will not know for sure until somebody else replicates this on an SX52 proto board. I am still leaning toward, a quirk in the compiler, the SX52 part of it, anyway.
Any ideas?
Ray
'·· File...... MyTut0228.sxb
'·· Purpose... SX/B Programming Template
'·· Author....·
'·· E-mail....·
'·· Started...
'·· Updated...
' Program Description
' Device Settings
DEVICE········· SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ··········· 4_000_000
' IO Pins
Led1 var RB.0
IRpin var RC.0
' Constants
' Variables
·temp1 var byte
· PROGRAM Start
' Subroutine Declarations
·BlinkLED sub
·Get_Code sub
' Program Code
Start:
· PLP_A = %0000
· PLP_B = %00000000
· PLP_C = %00000000
Main:
· DO
··· Get_Code
··· BlinkLED·
· LOOP
end
'Suroutine Code
Get_Code:
· do
return
BlinkLED:
··· LOW Led1···· 'Turn on the LED
··· PAUSE 1000
··· HIGH Led1··· 'Turn off the LED
return
'User Data
'·· File...... MyTut0352.SXB
'·· Purpose...·
'·· Author....
'·· E-mail....
'·· Started...
'·· Updated...
' Device Settings
DEVICE········· SX52, OSC4MHZ
' IO Pins
LED1 var RD.0
IRpin var RE.0
' Constants
' Variables
temp1 var byte
· PROGRAM Start
BlinkLED sub
' Program Code
Start:
· PLP_A = %00000000···· 'PLP_ activates the pull ups
· PLP_B = %00000000
· PLP_C = %00000000
· PLP_D = %00000000
· PLP_E = %00000000
Main:
· DO
· LOOP until temp1 > 216·· '*******
· BlinkLED
· goto Main
· END
' Subroutine Code
BlinkLED:
·· LOW LED1···· 'Low makes rd.0 pin output, sets pin to 0 (Vdd) led is on
··· PAUSE 1000
·· HIGH LED1··· 'High makes rd.0 pin output, sets pin to 1 (Vss) led is off
return
' User Data
  • RsadeikaRsadeika Posts: 3,877
    edited 2005-12-30 20:52
    Today I did some more testing. I feel pretty confident that the problem is with the SX/B compiler, for the pulsin command, when used with the SX52 device. Since I do not have an SX48 proto booard, you guys are on your own.
    Yesterday I determined that the pulsin command for the SX28 worked as expected. Today I eliminated the SX52 proto board as a problem, by having Jon's SIRCS_ISR program work as expected. The program has an asm simulation of what the pulsin command is supposed to be doing. I also ran his non asm version of SIRCS_ISR, that also ran as expected.·I guess since the SX52 is now EOL, then it's hard to say when the bug will be fixed in the SX/B compiler.
    I am not going to re-quote my "tip of the ...", but I will me more meticulous with making sure that the command is supposed to work as expected. Programming will take a little longer, but I will not end up chasing problems like I did a week or so ago.
    Ray
  • pjvpjv Posts: 1,903
    edited 2005-12-30 20:59
    Hi Ray;
    When it comes to SXB, I'm not fully up to speed on the nuances of the language, so I would have a tough time spotting anything incorrect or unusual. If you can convert and post both to as identical as possible assembly routines, I can can give helping a good shot.
    Cheers,
    Peter (pjv)
    Peter,
    I am not sure if this is what you requseted. As much as I can understand of this, I think Jon's code is really pretty good; I kind of like his coding style. The first snippet is basically an SX/B version of getting the code from the irpin. The second snippet is the asm version. Both of these work, so, that is what I used to eliminate·a board problem.
    Some where along the line I will have to sit down and study this code, and see what it really means.
    Ray
    ******CODE
    This is a snippet of the SX/B SIRCS_ISR program non-asm version, in here lies the pulsin command, somewhere.
    '_________________________________________________________________________
    INTERRUPT NOPRESERVE
    ISR_Start:
    ·· if hasCmd = 1 then ISR_Exit
    ·· if rxCmd = 1 then Check_Bit
    ·· if irpin = 1 then ISR_Exit·······
    Start_Packet:
    ·· rxCmd = 1
    ·· rxBit = 1
    ·· cmdWork = 0
    ·· bitWidth = 0
    ·· bitCount = 0
    ·· goto ISR_Exit
    Check_Bit:
    ·· if irpin = 0 then Update_BitWidth
    ·· if rxBit = 0 then ISR_Exit
    ·· rxBit = 0
    ·· if bitCount > 0 then Test_DBit
    Test_SBit:
    ·· if bitwidth > 74 then Next_Bit
    ·· rxCmd = 0
    ·· goto ISR_Exit
    Test_DBit:
    ·· cmdWork = cmdWork >> 1
    ·· if bitWidth < 34 then Next_Bit
    ·· cmdWork.6 = 1
    Next_Bit:
    ·· bitwidth = 0
    ·· inc bitCount
    ·· if bitCount < 8 then ISR_Exit
    ·· hasCmd = 1
    ·· cmdCode = cmdWork
    ·· rxCmd = 0
    ·· goto ISR_Exit
    Update_Bitwidth:
    ·· inc bitWidth
    ·· rxBit = 1
    ISR_Exit:
    · returnint 104
    This is a snippet of the asm version of the SIRCS_ISR program,·in here lies the pulsin command also.·This is a cut from Jon's original code. The variables apply to both snippets.
    ' Variables
    cmdCode··VAR·Byte···' IR command code (7 bits)
    cmdWork··VAR·Byte···' work space for cmd byte
    bitCount·VAR·Byte···' track bits received
    bitWidth·VAR·Byte···' measure bit width
    flags··VAR·Byte
    rxCmd··VAR·flags.0···' receiving command
    rxBit··VAR·flags.1···' measuring bit width?
    hasCmd··VAR·flags.2···' command code available
    temp1··VAR·Byte···' subroutine work vars
    temp2··VAR·Byte
    temp3··VAR·Byte
    · INTERRUPT NOPRESERVE
    ISR_Start:
    · ASM
    ··· JB··· hasCmd, ISR_Exit···' exit if holding command
    ··· JB··· rxCmd, Check_Bit···' receiving now?
    ··· JB··· IR, ISR_Exit····' exit if IR line idle
    Start_Packet:
    ··· SETB· rxCmd·····' set rx flags
    ··· SETB· rxBit
    ··· CLR·· cmdWork····' clear work vars
    ··· CLR·· bitWidth
    ··· CLR·· bitCount
    ··· JMP·· ISR_Exit
    Check_Bit:
    ··· JNB·· IR, Update_BitWidth···' still in bit?
    ··· JNB·· rxBit, ISR_Exit···' in idle period?
    ··· CLRB· rxBit·····' no, clear bit flag
    ··· CJA·· bitCount, #0, Test_DBit··' start or data bit?
    Test_SBit:
    ··· CJA·· bitWidth, #74, Next_Bit··' proper start bit?
    ··· CLR·· rxCmd·····' no, reset
    ··· JMP·· ISR_Exit
    Test_DBit:
    ··· CLC
    ··· RR··· cmdWork····' prep for next bit
    ··· CJB·· bitWidth, #34, Next_Bit··' "1" bit?
    ··· SETB· cmdWork.6····' yes, set it
    Next_Bit:
    ··· CLR·· bitWidth····' clear for next bit
    ··· INC·· bitCount····' update count
    ··· CJB·· bitCount, #8, ISR_Exit··' done?
    ··· SETB· hasCmd····' set available flag
    ··· MOV·· cmdCode, cmdWork···' copy work to output
    ··· CLRB· rxCmd·····' clear rx flag
    ··· JMP·· ISR_Exit
    Update_BitWidth:
    ··· INC·· bitWidth····' else inc width
    ··· SETB· rxBit·····' refresh in bit flag
    · ENDASM
    ISR_Exit:
    · RETURNINT 104·····' 26 uS @ 4 MHz
