how can i do to send the captured image to this forum
i would to post you two screen.
first is a screnn copy from my ping data logger,
second one is the same signal from my parallax oscilloscope.
Unfortunately i d'ont copy these screen in to a good format to send via parallax forum.
Problem is than controling time and frequency true debug terminal and optascoppe are not exactly same.
Thank's for your help,
michel,
ps, how can i do to send the captured image to this forum?
Post Edited By Moderator (Chris Savage (Parallax)) : 12/28/2005 7:34:31 PM GMT
michel,
paste into ms paint
better edit the subject line else you get a spanking
engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
·· Pictures (within reasonable size) are attached to your message using the Attachment Manager, right below the message editor.· I have seen this thread (And answered it) three times now...The duplicates have now been removed.· Please do not cross-post your messages.
Chris Savage
Parallax Tech Support
csavage@parallax.com
great america but so little whith is spirit
Getting back to your issue at hand... I just had the same problem... you can post PDF files, so you just need to convert your Word documents into PDF files... you can buy software to do this conversion or you can have it done for you for free... simply go to this site --> http://www.pdfonline.com/convert_pdf_2.asp
Once you get your files back, which happens instantly, you can then attach the PDF files to your post.
As soon as you post your files, we can work on your issue.
The American spirit is alive and well, it's just the media will tell you different.
