How to adjust my parallax oscilloscope with a ping sensor
i would to post you two screen.
first is a screnn copy from my ping data logger,
second one is the same signal from my parallax oscilloscope.
Unfortunately i d'ont copy these screen in to a good format to send via parallax forum.
Problem is than controling time and frequency true debug terminal and optascoppe are not exactly same.
Thank's for your help,
michel,
ps, how can i do to send the captured image to this forum?
michel,
http://forums.parallax.com/showthread.php?p=518491
I d'ont find any other way to capture them.
Regards from Belgium,
Michel
Once you get your files back, which happens instantly, you can then attach the PDF files to your post.
http://forums.parallax.com/showthread.php?p=564241
Chris Savage
Parallax Tech Support
csavage@parallax.com
