Out of Space!!!
I went out of space on a SX48. My program is writen in SX/B so I think I could save some space coding in assembler but I see two··problems: first,the code is rather complex to code in assembler (and I am not an expert in SX asm coding)·and second, I have realized that the code generated by the SX/B compiler is already·very good! So I don't think I could improve it much.
The question now is: what to do next ? Recoding everything in assembler ? Perhaps adding a second SX48 and share de tasks between them ? What to do when running out of space ?
By the way, the SX52 has the same space that the SX48, isnt'it ?
First answer next: As you know, program memory is segmented into pages. Hard to believe that all your program memory pages are filled up with code. After compiling the latest version of your program that did not run out of space, have a look at the list file ("Run - View List"). The list file shows you the generated machine code together with the addresses where it is stored in program memory. Hopefully, you'll find some empty space remaining in some pages. For a quick overview, after a compile, you can also do a "Run - Device" which will pop-up the Device window, showing you part of the program memory in hex in the E²Flash section. Scroll through the hex code, and see if there are any areas containing a number of subsequent FFFs. These areas are empty and can be filled with more code.
Im must admit - I'm not very experienced with SX/B to tel you how to move parts of SX/B-generated code into other pages - maybe, you will have to do this by cut-copy-paste in the generatd assembly code output file but I'm sure someone else with more experience will bail in here - Bean?
Greetings from Germany,
Günther
Chris Savage
Parallax Tech Support
csavage@parallax.com
If you post your code I'm sure we can figure a way to squeeze it in without resorting to assembler (not that there is anything wrong with assembler).
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
Forget about the past, plan for the future, and live for today.
