uMP3 via USB2SER
Hi Everyone,
· I have been working through Jon Williams Nuts & Volts atricle 'Sounds·Of The Season'·and have run into a snag.· For starters I'd like to estabilish communication to the uMP3 module using the Parallax USB2SER adaptor as Jon did.· There has been some success, in that the USB2SER drivers are installed and the virtual serial COM port is set up and running.· For background, I'm using a Gateway·notebook PC, Professional Development Board to supply +5VDC to the UMP3, and the USB2SER with Parallax USB·cable.· I am also using the·uMP3Config software from Rogue Robotics to 'talk' to the player.· After·three hours with this last night,·the best I could do is to read and write settings to and from the uMP3 using uMP3Config, but I could not get the player to play.· When using the 'Play' button in the software, I was·prompted to install and play a test file to the SD card, but when I chose 'Yes' or 'OK' I received many errors while the test file was being written to the memory card.· The SD card is new, has been formatted and tested outside this application, and works well.· My goal at this point is to update the firmware, test the player and then change the settings necessary to continue with the article and bring a BSII into the picture to run the player.· It sounds like Jon is busy moving these days, so I thought I'd ask if any of you have 'talked' to a uMP3 module via the USB2SER -- if so, I could use your help.
Tim
Tim
Back to packing....
Jon Williams
Tim
Jon Williams
THANKS FOR THE HELP AND GREAT ARTICLE JON!
Tim
Edit:
I hope there are more articles to come!
Edit:
I forgot to mention that I did get the firmware updated too, so all is ready in baud-ville·should a Prop-1 come along.
Post Edited (Tim-M) : 12/20/2005 11:04:06 PM GMT
Jon Williams
Thanks a bunch Jon,
Tim
Jon Williams
Happy packing and we wish you well in your move this busy time of the year,
Tim
