Stupid Math question
I haven't played with this stuff in years, and I just got my B2 module and an accelerometer.·· Now I question some (very basic) math and why it is there.
In the code for the accelerometer there are a number of debug statements, one of which is:
DEBUG ... xGForce.Bit15 * 13 ...
Can someone tell me what that is all about?
See Program MEMSIC2125.BS2 for a complete listing of the code . . . but I think I have most of it down.
Actually, while I am at it,·can anyone direct me to some formulae for calculating the directional·movement in the x-plane·and the y-plane?· Can this be done without a real-time clock?
Thanks.
Thanks.
xGforce.bit15··· ' xGforce is a variable and .bit15 is a Pbasic modifier specifying the bit 15 or the MSB of that variable
* 13···············'means multiply by 13.
You should probably download the Basic Stamp Pbasic editor herehttp://www.parallax.com/html_pages/downloads/software/software_basic_stamp.asp
Pick your operating system and download the appropriate Version then install and open it. The·Pbasic help file is excellent with· program examples yhou can paste and run.
If you do a search on "variable·" in the help file it will explain the Pbasic variable structure
Thanks, and any other advice/insight would be helpful.
· Jon got really tricky there. He is doing (xGForce.BIT15 * 13 + " ") this will print a space " "(32) if the number is positive or a "-"(45) if the number is negative. And of course the difference in ASCII is 13.
· You could change this to (xGForce.BIT15 * 2 + "+") and this would print either a "+" or a "-".
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
Forget about the past, plan for the future, and live for today.
The Stamp DEBUG command can deal with twos complement integers using the SDEC modifier. For example,
x = -12345
DEBUG SDEC x
will print the signed integer (-32768<=x<=32767) correctly with sign.
The code you referenced did not use that form so there is probably something else going on, for example, the number -12345 really represents the decimal value, -123.45 and you want the DEBUG to display it in that way. The SDEC command only works with integers, so to display the decimal you have to break it up. Something like this:
DEBUG x.bit15*13+32, DEC ABS x/100, ".", DEC2 ABS x
That would cover the bases for x both positive negative or zero. First it prints either a space or a "-" depending on the sign bit. 32 ascii is space, and "-" is 45 ascii, so 13 is added to space conditional on the sign bit. Then the program prints the digits to the left of the decimal point, then the decimal point, then the two digits to the right of the decimal point. The division by 100 is integer division, that drops the remainder. The DEC2 modifier prints two decimal digits, which allows for the case where the leading digit after the decimal point happens to be a zero. You dont want to print 123.3 when the answer should really be 123.03.
I haven't actually looked at the MEMSIC2125.BS2 program code to see what it actually going on in the rest of the DEBUG you quoted.
Another way to print out a "-" conditional on the sign bit is the following:
DEBUG REP "-"\x.bit15, ...
Instead of space, that method prints nothing if the number happens to be positive. Look up the REP modifier in the book. How you do it depends on the format you want to display.
Tracy Allen
www.emesystems.com
Jon Williams
Thanks, I get it now.
Don.
