Problem With My New Toddler!
The ball joints are constantly falling off. It takes a step, they pop off, it falters to the ground. Can someone help me out here? Chewing gum worked well til it hardened.
Info on all kinds of robosports:
www.freewebs.com/robotbattles
Chris Savage
Parallax Tech Support
csavage@parallax.com
If you did make the legs too tight, something has to pop loose and the ball joints would be most likely to do so.
I don't think it will damage anything.
The first time I assembled my Toddler it only walked backwards, but that is another story. If you have that problem -- just switch the servo connections or change the servo pins in the software.
