Radiation Sensor Interface
Hello, I was wondering if i could conect the following radiation senzor:
With any of the BASIC Stamp of the BOE Bot and I was wondering whats the best way to do it and what do I need?
Thank You
Post Edited By Moderator (Jon Williams (Parallax)) : 12/17/2005 6:16:56 PM GMT
Detector Technology: Cadmium Zinc Telluride (CZT) Sensitivity: 0.1 milliREM/hour Full Scale: 1,000 mREM/hour (Cesium 137) Outputs: Logic Level Alarm Signal, Dosage Rate, Accumulated Dosage Memory: 512KB Flash Memory Power Input: 3.6V @ Nominally 600 uA Power Consumption: <2.2mW Typical Battery Life: 15 months to approx. 3 years reduced power operation (7.2A-h Li/SOCl2 “C” cell) Communications: RS-485 Operating: Temperature: -20°C to +50°C ambient, Humidity: 5% - 90%RH non-condensing
Thank You
Logic·Level·Alarm·Signal: This is likely a "Y/N" proposition, Hi/Lo
Dosage·Rate, Accumulated·Dosage: These must be sent out in some format.· Is it TTL or RS-232?· How are the numbers sent out (binary, bcd, ascii, lsb first, msb first)?
If you've never STAMPed before, then you might consider a HomeWork board, available at RadioShack.· Are you an electronics person (technician or engineer)?· If so, you may prefer an BS2-OEM board (look that up on the parallax site.)
I see there that it says 'RS-485', so you might have to consider a RS-485 to RS-232 converter (no big deal that.)
[noparse][[/noparse] Please Edit your original post and enter a SUBJECT name.· Also, they'll probably move this one over to The Sandbox. ]
Post Edited (PJ Allen) : 12/17/2005 6:04:22 PM GMT
If you can give me the manufacturer and model number, I'll see what more I can find out for you. I have a freind who collects radiation detectors as a hobby. He probably has one of every model that was ever produced, going back as far as the Civil Defense units of the early 1950's.
I suppose I should add (in his defense) that he spent many years as a health physicist working with radioactive materials every day; thus the interest. He also directly supervised the disarming of nuclear weapons! Fun job, if you've got the NERVES for it.
Bruce Bates
Post Edited (Bruce Bates) : 12/17/2005 7:10:10 PM GMT
http://www.rftrax.com/radiation_sensor.xml
The Toxic Gas detector is here:
http://www.generalmonitors.com/products/toxic_ts4000.html
I am a 15 year old student and im very bad in technology i have no idea what to do.
Can you help me please?
The toxic gas sensor is only capable of detecting a single type of toxin at any time, requiring you to exchange the cylinder for each type of toxin, also the unit is quite large, something that would be unwieldy on a small robot, a larger form robot would be required.
·1+1=10
Post Edited (Paul Baker) : 12/17/2005 7:23:32 PM GMT
Post Edited (StarteR2) : 12/17/2005 9:20:08 PM GMT
Do you have one of these sensors?· If so, can you·post some·pictures of it?
How much does the radiation sensor cost, and is it really available? (hehe!?).
Other manufacturers of toxic gas sensors are www.figarosensor.com/ and www.synkera.com/products/sensors.htm. Most of those are catalytic sensors that require a heater (read battery power on your roving robot), and they take a long time to warm up (10s of minutes), and they are quite specific as to target gas. Some active gases like carbon monoxide can be sensed with electrochemical cells in a poteniometric circuit, as in the home safety CO detector. These days a lot of research is going into "electronic nose" (google it!), in order to have one instrument that can detect and identify a wide range of compounds and do it cheaply and in a small form factor. I don't think you can buy one off the shelf yet!
Tracy Allen
www.emesystems.com
Here is the bad news about that radiation detector, directly from someone who wanted to use them in a similar, stand-alone application:
quote
The CZT sensor is NOT a stand alone unit. It's designed to be daisy-chained with other units and read out remotely, OR for personal use, piggybacked with a module which allows it to be read out on a local LCD. Packaging is at the descretion of the user.
Programming is done by a PC using their proprietary software, and so is clearing the memory, resetting parameters, and even turning it on or off, off being a low power standby mode. Code is NOT available, nor is the comm protocol. Windows software costs $1,400 for one unit or multiple uints. Programming / reading interfaces are sold separately.
end quote
I asked the question "Is there a more apporpriate unit for portable, remote use which is RS-232 compatibale, and reasonably priced?". I'll let you know when I get an answer to that question as well.
Bruce Bates
Post Edited (Bruce Bates) : 12/18/2005 5:05:07 AM GMT
CHECK OUT THIS WEB SITE CARFULLY. THEY HAVE UNITS WHICH I THINK YOUR NEEDS. THEIR UNIT WAS COMMONLY USED WIITH THE POCKET PC HP 100 & 200.
http://www.aw-el.com/
73
SPENCE
K4KEP
CHECK OUT THE ITEM ON THEIR WEB SITE ON THE "KANSAS NEAR SPACE PROJECT" USING PARALLAX STAMP.
73
SPENCE
K4KEP
I JUST GOT A EMAIL FROM PAUL VERHAGE KD4STH OF THE "KANSAS NEAR SPACE PROJECT" I AM WAITING FOR PERMISSION TO POST HIS REPLY ON THIS FORUM. HOLD ON TIGHT, I THINK IT IS GOING TO BE REAL GOOD NEWS FOR YOU. HE USED A AWARE ELECT. RM SERIES RADIATION COUNTER INTERFACED TO A STAMP IN THEIR PROJECT.
73
SPENCE
K4KEP
Post Edited (SPENCE) : 12/19/2005 10:59:46 AM GMT
>Please do. The Parallax website has my book on near space. Go to
>Resources, Customer Applications. Then under the science section you'll
>find my book, Near Space. Chapter 8 is all about science experiments.
>Page 37 has my section on the Aware Gieger Counter. Here's a link to
>the page, http://www.parallax.com/dl/docs/cusapps/NearSpace8.pdf. I
>give directions for connecting the counter and collecting data.
>Paul
>I'll be back in town in two weeks, until then, I won't have regular
>access to email. But there's enough in my book to get everyone started.
>Paul
> I've written up something in my book and I'm getting ready to write an
> article for Nuts and Volts magazine. When I get home, I'll put
> something out on the Parallax forums.
> Paul
73
SPENCE
K4KEP
