Coin Machine
Microman171
I have made a coin machine and I've got all the files at the bottom in a zip at the bottom of the page. I decided to do this because it controls a relay for swithing a stamp to play a game ect... PLease reply on this post as I liked making it and I thought parallax might make a coin machine and sell it for the basic stamp. Just an Idea.
Signing off MICROMAN171
1 + 1 = Window
0............................................0
0.(Microman171@hotmail.com)..0
1 + 1 = Window
At one point I was looking to build one from scratch but couldn't get past how to sort coins 1 at a time!
I thought about magnetics and vibration tables....most people only want to drop a handfull in and be done with it...if they have to put one in at a time, then they can just take the time to count too!! haha
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
1 + 1 = Window
Also, if you put it in the projects section, think about including the stamp code!
Steve
·1+1=10
Timothy Gilmore
Place the IR LED and photo-transistor oposite eachother on the made coin slot have a look here and wire up the circuit. what happens is the coin goes through and switches off the photo transistor so it needs to be reversed (BC558 or similar PNP transistor) and the outputs on the relay are there. please reply if you need more info
1 + 1 = Window
