Servo Refresh Rate-does it really help torque?
I guess I could just make some sort of a test, but I wanted to get some expert advice on this. How significant is the refresh rate of a servo to its torque output? For example, if a servo is rated for 50oz/in on standard RC equipment (which I believe, has a standard refresh rate), then by how much could that refresh rate be increased using a stamp and how much could the torque be increased by?
On that note, I usually use a refresh rate of "2304" with the Javelin's PWM class. What is the largest value that it could have, and what (if anything) is wrong with having it refresh more often?
However, if you DO refresh as specified (20 to 50 mSec) then the Servo drives the shaft, with the full Servo torque, to the position you've specified. Shortening the refresh period below 50 mSec does NOT increase this torque.
So, when a Servo is rated at 50 oz/in, that's the maximum torque that Servo can put out. Changing the control signal won't increase this value.
·· I don't think it's·a matter of improving your torque...I think the real thing is that servos require refresh every 20 - 50 mS...Somewhere in there is the sweet-spot for your servos.· The further you deviate from that the worse your torque is going to get.
·· The same analogy works when centering/calibrating servos on a BOE-Bot or SumoBot.· When the Boy veers to one side you don't speed up a servo to compensate, you slow the other down.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Chris Savage
