radiowave
hi.....
everyone can help me......
i have a few question about radiowave......
1. how to use a simple schematic about radiowave?
2. what means about radiowave?
3. what min voltage for draw a simple schematic radiowave?
There seems to be a language barrier here. Often non-native English is just too general or too vague.
I am guessing the following:
By 'radiowave' you really mean electronics.
If that is so, your questions begin to be understandable.
1. Schematics are a system with its own vocabulary. The lines represent wires and the symbols represent devices.
You need to learn what each device can do before you can easily understand a schematic.
2. [noparse][[/noparse]I just cannot under stand the question}
3. While I am again unsure about your question, most of the digital electronics require at least 3.3volts.
LEDs are about the only thing that is useful and can operate on less than that, maybe 2.2volts.
I am also guessing you are quite young. If that is so, don't worry about your questions sounding odd -- just keep trying and try to improve your English along with your electronics. You will learn two skills at the same time.
It sometimes gives the wrong translation too, but it may be close enough for us to understand.
·1+1=10
I now get a friend to help me re-type the questions :-
I want to design a simple radiowave transmitter to install in my car.
I also want do design a simple handheld radiowave receiver to find my car in a big parking lot.
Can I use the SX to do this?
Anybody got any ideas on simple RF circuits that is easy to understand and assemble?
Thank you.
73
spence
k4kep
I think you can use a low power AM transmitter to avoid problems with the law.
AM is quite directional with a ferrite antenna, so it may be able to tell you the approximate direction of your car.
( with some smart shieldings )
Unfortunately, I am not an expert of RF circuit designs.
Hopefully, somebody else with RF circuit experience can help you.
The SX is not a radio transmiter or a radio receiver. It is a microcontroller that is used to communicate between digital devices [noparse][[/noparse]things like computers and computer controlled motors]
Sorry, but this web site cannot directly help you.
SPENCE is a licensed amature radio operator and can answer your questions, but this discussion should be moved to the SANDBOX section of the Forum as it isn't about the SXes.
If someone from Parallax decides to move it, I hope they will email you to let you know where to look.
Warm regards,
http://www.linxtechnologies.com/
The have some devices that·do not·require·compliance testing...
-Dan
(N8XJK)
You first need a matching set of transmitter/receiver operating in a frequency range that is free to be used for such remote-control systems in your country. As a beginner, I would not try to build the transmitter and the receiver by myself. Instead, I would buy a set of off-the-shelf units.
Important is that the transmitter can be modulated and the receiver has a demodulated output (both digital, if possible). Also check for the maximum possible range between transmitter and receiver for a good operation, and keep in mind that concrete walls and floors usually found in garages can reduce this range dramatically, depending on the transmit frequency.
Greetings from Germany,
G
Guenther, my motorcycle has a rf security lock that does all that now. Everybody here has one on their car or cycle.
I was thinking he wanted to get started with walkie-talkies as he mentioned AM.
I also have an RF securoty lock in my car but the range between tre transmitter and the car is much too small to use it as a "car-finder".
G
I was also thinking of a RF beacon that transmits for just 50ms every second from the car.
Can you build such a transmitter and a handheld receiver that can be interfaced to an SX?
The SX could rotate the ferrite core antenna with a small motor to get the approximate direction that has the strongest reception.
It could then blink one of the LEDs to show the direction of the car.
Guenther,
I think Zera could be a student who needs to do this project before graduating.
Buying the RF modules off the shelf might not get her good marks for this project.
Are you an expert on RF circuits?
I am an Avionics Rf engineer and just spent close to 50 thousand US bucks to certify a simple avionics wireless link for a wireless headset to a panel mount Avionics radio. This was the FCC transmitter and antenna radiation test cost.
Look at these links and you'll find a lot of info on the various certifications, requirements etc.
http://www.radiotronix.com/support/content_by_cat.asp?contentid=199&catid=114
just an example of what the regulations are like. For example she would need to design her device to comply with standards like this.
http://rfcomply.com/products_services/faqs/
rcarmel
MM
