Servos shaking
Hi!
I am using Parallax Servo Controller (PSC) USB to control 6 servos (Futaba S3001).
Sometimes the servos start to shake.
Is it possible that the controller doesn't send "clean" signals to the servos?
The servos are connected to a separate power supply (5v).
What I do is to send commands via RS232 that tell the controller which servo will be moved.
Are the ground lines of the servos, Stamp and PSC all connected?
peter
Peter C. Charles
Director, Research and Technology
CyberBiota, Incorporated
Peter.charles@cyberbiota.com
http://www.cyberbiota.com
While 5V may work, my experience in R/C suggests this is a little on the low side. Forces tended to be higher (mostly ground based high speed cars and boats), so my opinion here may be incorrectly biased.
More significantly, it was not unusual to have a slight "shake" depending on exactly where the servo was "pointed" at. Move the control stick a hair one way or the other, and the shake was gone. By hair, I mean just that, a hair.
As a suggestion, try chaning the position by a few units and see what happens.
John R.
8 + 8 = 10
require far more power than the USB port can supply.
Therefore I use a separate power supply 5V for the servos.
The following document shows how to connect the power supply:
www.parallax.com/dl/docs/prod/motors/PSCusbManBv3_3.pdf
Maybe the servos need more power, 6V.
The processor used on the PSC requires a supply 5 VDC. Use a separate power supply for
your servos. In general, servos require 4-7.5 VDC. Be sure that the servo power source can
supply ample current at the proper voltage and will not damage the servos.
In my experience, make sure your power supply can provide at least an 1 amp when driving multiple servos.
JJ
Post Edited (Oualid) : 12/12/2005 8:47:35 AM GMT
·· What firmware revision does your PSC have?· There is example code in the documentation to determine this.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Chris Savage
Thanks for the help everyone!
