.SRC file is where?
In the SX-Key editor how do I view the compiled .SRC code of my .SXB program?
The programmed seemed to do this automatically, then seemed to stop.
Can anyone help?
-DSPRO
Can anyone help?
-DSPRO
After I write an SX program in SXB I usually follow these steps:
(1) Save the program (Cntrl S)
(2) Assemble the program (Cntrl A)
(3) View the list file, which is the assembly source code (Cntrl L)
The List file can also be accessed by clicking on Run (in the menu bar), then clicking on view list from the drop-down menu.
Also, as noted in my first step, before assembling or transfering a program to the SX, I save it first. This is in case I encounter any problems with Windows hanging or crashing.
Alan
"I learn when I succeed, but I learn more when I fail."
C:-->Program Files-->Parallax Inc-->SX Key v3.1-->Compilers-->SXB-->Output Files
If you compile a program from the SXB and there is an error in compiling, the SRC
file becomes available in the file selection window.
Beau Schwabe
IC Layout Engineer
I managed to have two Parallax directories {Parallax Inc [noparse][[/noparse]which seems to be the true Parallax directory] and Parallax [noparse][[/noparse]which I cannot seem to understand the need for]}.
I am not sure why. I may have gotten a bit too creative and forgotten about it.
But it is high time to migrate it all back to the defaults of the regular configuration.
Then, I will just make a backup image via Ghost on my second harddrive.
Greetings from Germany,
G
i had the same parallax inc & parallax folder issue on my comp. i'm fairly certain i picked up the second directory when i installed parallax's usb scope.
rox on
nick
engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
