Stamps supply tolerance ( Max. and minimun)
Hi,
Only to know the minimun an max. voltage supply using
Bdd ( not Vin) because I have power suplies that
suplies 5.19 Volts ( not 5.00 volts) .
Other power suplies that I have bring 5.10 or 5.12 but I would like
to know the tolerance of all basic stamps models.
This information is very usefull because I can't use the "Vin"
Thanks, Joe
Thanks, Joe
·· The 5.12V should be fine.· They way you would find the maximum allowed would be to research the datasheets for the interpreter and EEPROM.· But it should be close to 5.5V at the higher end, perhaps more.· 5.12V is okay.· Of course, it's good to stick close to the 5V specified, but there is a little leeway.
Chris Savage
Parallax Tech Support
csavage@parallax.com
