PDB Audio Gain
Mike Cook
Is there any way to increase the audio gain on the PDB (LM386)? I'm using it with the EMIC module and can't seem to get the audio loud enough.
"OEM NMEA GPS Module" Now available on ebay for only $19.99, FREE shipping until 2006!
Product web site: http://www.allsurplus.net/Axiom/
Jon Williams
It's the gain programming capacitor between pins 1 & 6.· See Page 6 of 10 of the attached PDF (it's page 5 of the datasheet itself.)
There are a few versions of the LM386, the DIP-8s have different output powers.· So, there may be a power limitation and matters of distortion with increased gain.
I've been using some amplified computer speakers to increase the EMIC's audio but I'm getting a lot of buzzing from these. I'll try your book shelf speaker idea.
PJ - I'll check out adding the cap to 1 and 6 on the LM386
Those would be pin 1 & 8, Mike.· Sorry, I had a presbyopic episode.
I'll check out the data sheet on the LM386 tonight.
Jon Williams
the·schematic in the post immediately preceding shows the gain capacitor's Positive electrode going (via the switch) to the LM386's Pin 8 ("Boost B"), whereas the device datasheet indicates that this capacitor's Negative electrode should go to Pin·8 and the Positive electrode should go to Pin 1.
· Sorry for not addressing this sooner - I've been terribly busy.
· The function of the cap is but to bypass a resistor and thereby help establish the gain.· The LM386 cares not about the polarity of the cap.· In fact we could (perhaps should) have used a non-polarized 10uF cap and things would have worked just fine.· The orientation of a polarized·cap is selected empirically by· measuring the difference between the AC voltage present on pin 1 and pin 8 at any given time.· The pin that is more positive gets the positive leg of the cap.
· During development of the AP-8·our testing showed that pin 1 was more positive than pin 8 half the time.· So in this case it appears that the cap is happy in either/neither orientation.
John Barrowman
Engineering
