Help - I can't find a 5mm IR Receiver
Does anyone know if there is a IR receiver that is in a 5mm LED package? I can find 5mm IR emiters, but I can't find any 5mm receivers that have the same package type as the emiters.
The below image is the type of package I would like the receiver to be.
I have searched all over the net with no luck. Thanks for any help.
I have a project where I would like to build an IR distance sensor in a custom machined robot head. the eyes are going to have 5mm holes where the above pictured·LED emitter will be inserted. I want to find a receiver that closely matches the dimentions of the emitter package type.
Here is an example:
The Sharp GP2D12 Analog Distance sensor will not work with my custom design, therefore, if I can get the individual components, I can mount those in my custom design.
Post Edited (SN96) : 12/5/2005 4:11:22 PM GMT
Are you aware that the receiver in the Sharp sensors is the hard part? - it's a device that reports where along its length a spot is, rather than the brightness of the spot. The processing electronics on the output of this device is tricky, too - some very low noise logarithmic amps, certainly not trivial to replicate.
(If you're thinking of a wide array of IR photodiodes, are you sure you want 5mm? 3mm might be better for resolution)
Steve
www.jameco.com
Thanks for trying to help guys, I really appreciate it.
You might have to optically isolate the different channels so you don't get cross talk....
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
Or if you need it today - you can get it at Radio Shack for $1.59 www.radioshack.com/product/index.jsp?productId=2049724&cp
Steve
I though about using PING sensors but they have a spacing that would not fit my design. Could I get a ping sensor, desolder the sensor components from the board and epoxy them in the eye sockes, and soft lead the sensor components to the original circuit board? Would that work?
You can even get 6mm diameter 40KHz ultrasound transducers, too - from Farnell, among other places. Not sure if Parallax sell them.
I don't know how cunning the ping is at ignoring its transmit pulses - if it's susceptible, you might need to soft-mount the transducers in silicone, to reduce the vibrations going straight through the plastic of your design.
Steve
The PING takes a finite amount of time to detect the return pulse. If that were possible the range would be much closer. As it is, the minimum range also has
some bearing on this, since it limits how quickly the PING can respond to a return pulse. I'm not sure if I am being clear or not, but suffice it to say you
wouldn't be an issue. (Monday...)
(This one doesn't seem to be showing up on the Forum, from here).
It sort of depends if the PING is doing the crude 'no response possible before time T', or a more elaborate 'no response before time T unless it's bigger than this template of silence I stored earlier' - which will let you get much better up-close performance. There are definitely plenty of options to be had, and, if customers are going to start changing the transducer type , mounting method and positioning, your precalculated times & amplitudes aren't going to suit everybody any more.
(Sorry, final year university project was a rather ahrd-core ultrasound implementation, and I've never been able to shake it off [noparse]:)[/noparse]
Steve
If you find that the PING always reports seeing something up close, be prepared to sink the transducers fiurther back into teh eye sockets, or give him a nose. Probably not needed, though, with any luck.
Steve
Here is another pic of several views of the revised design. Correction - The speaker is 36.5mm and not 20.1mm
Post Edited (SN96) : 12/6/2005 3:45:39 PM GMT
