Power supply for SX48 proto board.
I need to power a SX48 proto board with 16V DC from an AC adapter.
I think 9VDC is the max for the proto board.
Is there some simple way to power the SX PB with this adapter?
Thanks.
- - - PLJack - - -
Perfection in design is not achieved when there is nothing left to add.
It is achieved when there is nothing left to take away.
Thanks.
- - - PLJack - - -
Nate
Jon Williams
Chris Savage
Parallax Tech Support
csavage@parallax.com
In that way,
1/ You dump the heat via a regulating device that is off the board and may be sacraficed if you have the wrong hook up.
2/ You have a sure 9Volts to avoid confusion if you mix up power supplies or if you are trying to power a differenct set up that is less tolerant.
Other people think this is all silly, but...
Frankly, I have various Basic Stamps that I want to power directly and I have the SX-48/52 proto board. I also have a mix of other things which include some low drop-out regulators on homemade boards that cannot handle as high a voltage. I also have the SX-28 board.
I jump in and out of projects all the time and may switch wall warts if someone gives me a freebie.
So this is my 'failsafe' set up.
Jon Williams
Thank you All!
Great stuff. I did not know you could drop so much voltage into a proto board.
That would explain the heat sink on the LM2940.
I like Kramer's idea of a 7809.
Thanks for the prompt response.
Sorry for the delay. I have dropped off this forum as of late but that will be changing soon.
See you all then
- - - PLJack - - -
