Dlp-flash
I recently purchased a board from DLP Design that has a USB FIFO chip interfaced to a SX48 (DLP-245SY). To go with that board I purchased their Flash programmer (DLP-FLASH) which looks very, very similar to the SX-Key except that it's USB instead of RS232.
Is it possible to use the DLP-FLASH with the SX-Key IDE?
It looks like I can save the hex file in the IDE and then load it with the DLP-Flash application. Besides being cumbersome, I lose some of the capabilities of the IDE.
I want to avoid having to buy the SX-Key adapter after spending $75 for the DLP-FLASH.
Ok, Ive looked a little further into it, the SX-Key and the DLP FLASH are pin compatible if you ignore the 5th socket which isn't used for SX programming, connect it the way it is shown on http://www.parallax.com/dl/docs/prod/sx/sxkeyman1_1.pdf#page=9
install the SX-IDE and try to see if it works. And it does not support in circuit debugging.
·1+1=10
Post Edited (Paul Baker) : 12/1/2005 5:50:47 PM GMT
The DLP-245SY can be programmed using either device, you just have to be careful about the extra line when connecting·DLP stuff with non-DLP stuff.
Thank you for your replies. Once I get past the "hello world" types of programs I'll likely pick up one of the SX-KEYs. The additional capabilities will be worth it.
