Hyperterminal use with USB2SERIAL adapter
Hello I was·wondering if anyone could assist me with this issue.· Recently I saw a post regarding the use of hyperterminal in conjunction with an ADC in the following post:
http://forums.parallax.com/showthread.php?p=555332
My question is the following; I would like to be able to the same thing but I am unsure of a few things.· Would it be possible to use the USB2SER adapter, offered by Parallax to view this output data via hyperterminal?· If so how can I go about connecting the SEROUT pin(s), in this case RA.3 from your demo program,·correctly to the adapter?· And how can I get hypterminal on my PC to monitor this?·Thanks in advance for any help.
Jon Williams
Jon Williams
LTC1298
Ch0: some value
Ch1: some value
⌂⌐║╢╗∂◊○◘●⌂⌐║╢╗∂◊○◘●⌂⌐║╢╗∂◊○◘●⌂⌐║╢╗∂◊○◘● and it keeps looping.·
How can I fix this?· I think this is occuring because it is a 12bit ADC and hyperterminal reads a max of 8bits.· Therefore leaving 4 bits to carry over and add to the next set of 8.
2) Can I run the same program on an 8bit ADC, such as the ADC0831 sold by Parallax Inc.?· I know the pins are a little different but I believe that the code can be changed easily.
Jon Williams
Jon Williams
