ezLCD power on and off
I am using a ezLCD that has a power on/off line.
The manual says:· +3.6 to +7v turns ON the ezLCD-002 power.· 0 to +1v turns oFF ezLCD-002 power.· Open leaves the ezLCD-002 power unchanged.
························· Tmin = 1ms, Rin > 250 KOhm
Can someone explain to me how to make a circuit that will allow the javlin to power on and off the ezLCD-002.
BobVal
BobVal
Connect an I/O pin via 1k resistor to that digital input.
static final int ezLcdPowerOnOff = CPU.pin9; //power control pin
CPU.writePin(ezLcdPowerOnOff,false); //turn power off
CPU.writePin(ezLcdPowerOnOff,true); //turn·power on
regards peter
I think maybe their write up is wrong.
BobVal
Power ON/OFF
When any of the above power sources is connected, the ezLCD-002 may be powered on by:
· applying a positive voltage (2V to 7V) to the ON/OFF pin for at least 1 ms or
· by pressing the ON button (Figure 6) on the back of the display
The ezLCD-002 may be powered off by:
· connecting ON/OFF pin to the ground for at least 1 ms or
· by pressing the OFF button (Figure 6) on the back of the display
· The OFF button has the priority over the ON button.
When the ON/OFF/ pin is jumpered to the power source, the ezLCD power will be cycled by
connecting and disconnecting the power source.
So try this:
CPU.delay(15); //1.5 msec
CPU.setInput(ezLcdPowerOnOff); //make pin floating
regards peter
The on works fine, but the off does not seem to work.
Thanks for trying.
I think I will go with turning the backlight off and clearing the screen to either white or black (whichever turns of the pixels).·
Because turning the power off on the ezLCD-002 will also stop the touch from waking it.· So I would have to add a push button to my design to wake up.· Where by clearing the display to an off pixel color (and not writing to it) will make the lcd act as off but when someone hits the touch pad I can notice that and start drawing to the screen again and allowing input.
So seeing as you know alot, is turning all the screen white the same as setting off the pixels or do I have to turn the screen black to shut them off?· I have tried it both ways and I think white is what I need to do or at least it seems to look off then where the turning them black appears to be off but stands out more?
Thanks again
BobVal
As I understand it, a voltage between 1V and 2V at the on/off pin does not change the power state.
Try this (resistor divider):
+5V --<3k3>---+---<1k5>-- GND
connect + point to both Javelin I/O pin and ezlcd power on/off pin.
Making the javelin pin an input will leave (1500/(1500+3300))*5V = 1.56V on + point.
Try the code now, this may work.
regards peter
instead of CPU.delay(15);
Maybe the ezlcd is less sensitive than specified in the manual. 10 msec should
really be enough.
regards peter
