code question
Hi folks,
I am learning assembler and have a few questions.
1. here are·two sequential·commands:
mov w,#%11111110
mov !rb, w
I see this a lot, but Guenther's guide doesn't clear up for me why you can't say
mov !rb, #%11111110
Why do you have to copy the number into register W and then copy it again to where you want it? Can't you just plug the value where you need it?
2. Where is the documentation for SX/B language so I can program in it if I need to?
3. Is it possible, should it ever be necessary, to·have one SX output port feed the input of another SX chip?
Thanks -
mov w,#%11111110
mov !rb, w
mov !rb, #%11111110
Thanks -
2. The SX/B documentation is online in the help file.
3. Sure -- just make sure that you don't create an electrical conflict (both outputs and in opposite states); you can prevent programming errors from doing damage by making the connection through a 1K resistor (this limits the current enough to prevent damage to either chip).
Jon Williams
1)
Due to the internal structure (12 bits per instruction code), the SX does not allow for instructions to directly move a constant value into a register, or for moving the contents of one register into another. So, the W register will have to be used as temporary buffer.
Actually, instead of
mov w,#%11111110
mov !rb, w
you can say
mov !rb, #%11111110
i.e. use a so-called "multi-word", or "compound" instruction. As the SX can't execute this as "native" instruction, SASM automatically translates this into two separate instructions, i.e. into
mov w,#%11111110
mov !rb, w
2)
Select "Help" and then "SX/B" in the SX-Key IDE, any you will enter into an excellent help text, created by Jon Williams
3)
Hey, I noticed that Jon was faster this time - so I have nothing to add to his advise.
Greetings from Germany,
G
Jon Williams
Nevertheless, I was "instructed" by my wife that I better take some days off from tomorrow until Monday to visit some cities with nice Christmas markets the next days.
I finally agreed - Arghhh...
G
