SX52 heatsink for a PENNY????
cbmeeks
I have been building a NTSC GPU using an SX52 (protoboard). I have been running at 50Mhz and the chip gets a little warm. We brought this up before but I want to push it to 80Mhz and put a heatsink. Well, until I can buy an official heatsink with some thermal grease, I decided to put a penny on the SX52!!! Yeah, I just put it right on. I made sure the penny didn't touch any pins and I am careful not to move the penny.
It seems to be working...lol
The penny is pretty hot. So, I wonder how effective is this temporary fix? Or, could I just get some thermal grease and continue to use pennies until the final project? yes, I am cheap. hehehe
thanks!
cbmeeks
http://metroidclassic.com
DMCA Sucks
RIAA Sucks
thanks!
cbmeeks
DMCA Sucks
RIAA Sucks
Greetings from Germany,
G
John R.
8 + 8 = 10
from lrs.ed.uiuc.edu
1947-1962 3.11 g 19 mm 95.0% Copper and 5.0% Zinc & Tin (bronze mix)
1963-1982 3.11 g 19 mm 95.0% Cu and 5.0% Zinc
1983-2002 2.50 g 19 mm 97.5% Zinc and 2.5% Copper (20% lighter)
EDIT: There is no silver in a dime anymore!! (wow, who knew!): Dimes (and quarters) are 75%· copper and 25% nickle outside with copper on the inside: but yes, copper is still 4 times more thermal than zinc.
So it looks like a Dime or Quarter would actually be a better choice of coin.
Post Edited (Paul) : 11/23/2005 5:01:08 PM GMT
http://www.allelectronics.com/cgi-bin/category.cgi?category=270&item=HS-125&type=store
need some type of heat conductive glue to attach, was·thinking of getting a few myself.
"OEM NMEA GPS Module" Now available on ebay for only $19.99
Product web site: http://www.allsurplus.net/Axiom/
Thanks, but 40 CENTS!!! I'm not made of money!!! lol
Seriously, thanks guys....I currently don't have any thermal grease/glue so this is about as good as I can do. I will put a quarter on and see if it's any better.
But for prototyping, the penny goes a long way! hahaha
happy thanksgiving everyone!
cbmeeks
DMCA Sucks
RIAA Sucks
There I saw very tiny heat sinks in day-glow blue aluminum. They seem to be for cooling your RAM chips, so they come in sets for about $5USD [noparse][[/noparse]$150 Taiwan dollars].
I looks like one would fit nicely atop the SX-48 or SX-52 and create quite a bit of convection. They are about 3/8 inch square and the same in height with 8 to 10 fins.
I·just happened to have some change sitting on my desk and·I couldn't stop thinking about using a penny for a heatsink, not that I really need one. Use a Dremel (or simular type tool) smooth one side of the penny. This would increase the·contact area between the·SX and the penny to improve heat transfer, even if you do end up using thermal grease. I'm guessing the side with Lincolns face would require the least amount of work. His head looks bigger than the monument, but there is less lettering. Depending on which speed you run the Dremel, you could probably save 5 or 10 seconds of work. You might as well be lazy if you're going to be cheap
I don't·actually·know how well it would work but it's my 2..err 1 cent
You could make a large foil disc and put a penny on top to hold it down. Now THAT's come cheap heat sinks...hehehe
DMCA Sucks
RIAA Sucks
