SX/B Word variable
I think I have been down this road before. I am trying to do a pbasic translation of an IR remote control/IR detector system. I have an IR detector on rc.0, which·is setup to scan for remote codes. The first hurdle, rctime is requesting a byte value, meaning I guess a value of 255 or less, I need to test for >1000. I am having trouble conceptializing the loop that would be necssary to take a value of >1000 and test for it in one cycle I guess. Basically it is supposed to test for >1000 first to get out of the first loop, then goto the next loop and test for 500, 300, 300, 300, 300, 300, 300. If I can get a grasp on that first do ... loop, then I could probably handle the rest.
Thanks for any help.
*** code
'test1.sxb
device sx28, oschs3, turbo, stackx, optionx
irc_cal irc_slow
freq 4_000_000
program start_point
WORD con 2
irPulse var byte (WORD)
remoteCode var byte
start_point:
tris_b=0
do
remoteCode = 0
·do
·rctime rc.0, 1, irPulse, 2 'error: byte parameter expected
·loop until irPulse > 1000 'error: byte parameter expected
loop
'led_on:
'rb=0
'return
'led_off:
'rb=1
'return
sleep
*** code
'test1.sxb
irc_cal irc_slow
freq 4_000_000
program start_point
WORD con 2
remoteCode var byte
start_point:
tris_b=0
do
remoteCode = 0
·do
loop
'led_on:
'rb=0
'return
'led_off:
'rb=1
'return
sleep
Get_IR_Byte:
· DO
··· PULSIN IrPin, 0, bitWidth
· LOOP·WHILE bitWidth < 220
This works because the default resolution of 10 uS means a 2.4 millisecon pulse from the IR receiver would put a value of 240 in the variable called bitWidth.· You could receive the next eight bits like this:
Get_Bits:
· temp1 = 0
· FOR idx = 1 TO 8
··· temp1 = temp1 >> 1
··· IF bitWidth > 100 THEN
····· temp1.7 =·1
··· ENDIF
· NEXT
· RETURN temp1
Jon Williams
You need to use the resolution parameter of RCTIME.
I see you are using "2" now, just increase it to "8" and the value returned will be 1/4. So if using "2" would have returned 1000, then using "8" would return 250 and you can just test if irPulse > 250
irPulse VAR BYTE
DO
· rctime rc.0, 1, irPulse, 8
LOOP UNTIL irPulse > 250
rctime rc.0, 1, irPulse, 4
IF irPulse > 150 THEN
· ' whatever
ENDIF
IF irPulse > 250 THEN
· ' whatever
ENDIF
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
Those that would give up freedom for security will have neither.
****code
' {$STAMP BS2}
' {$PBASIC 2.5}
·IrDet PIN 2· 'Activity board
·ThresholdStart CON 1000
·ThresholdPulse CON 500
·ThresholdEdge CON 300
·One CON 1
·ChUp CON 16
·ChDn CON 17
·VolUp CON 18
·VolDn CON 19
·Power CON 21
·Mute CON 20
·Last CON 59
·IrPulse VAR Word
·remoteCode VAR Byte
·DO
· GOSUB GetCode
·IF (remoteCode > 0) THEN GOSUB processCode
·LOOP
END
processCode:
' DEBUG CLS, "Press Button ",CR
' IF (remoteCode = ChUp) THEN DEBUG "CH+ BUTTON"
·IF (remoteCode = ChUp) THEN GOSUB GoFore
' IF (remoteCode = ChDn) THEN DEBUG "CH- BUTTON"
·IF (remoteCode = ChDn) THEN GOSUB GoBack
' IF (remoteCode = VolDn) THEN DEBUG "VOL- BUTTON"
·IF (remoteCode = VolDn) THEN GOSUB GoForeLeft
' IF (remoteCode = VolUp) THEN DEBUG "VOL+ BUTTON"
·IF (remoteCode = VolUp) THEN GOSUB GoForeRight
' IF (remoteCode = Power) THEN DEBUG "Power BUTTON"
·IF (remoteCode = Power) THEN GOSUB RobotStop
·IF (remoteCode = Last) THEN GOSUB DriftRight
·IF (remoteCode = Mute) THEN GOSUB DriftLeft
RETURN
GetCode:
·remoteCode = 0
·DO
·RCTIME IrDet, 1, IrPulse
·LOOP UNTIL irPulse > ThresholdStart
· PULSIN IrDet, 0, irPulse
· IF irPulse > ThresholdPulse THEN remoteCode.BIT0 = 1
· RCTIME IrDet, 0, irPulse
· IF irPulse > ThresholdEdge THEN remoteCode.BIT1 = 1
· IF irPulse > ThresholdEdge THEN remoteCode.BIT2 = 1
· IF irPulse > ThresholdEdge THEN remoteCode.BIT3 = 1
· IF irPulse > ThresholdEdge THEN remoteCode.BIT4 = 1
· IF irPulse > ThresholdEdge THEN remoteCode.BIT5 = 1
· IF irPulse > ThresholdEdge THEN remoteCode.BIT6 = 1
· IF (remoteCode < 10) THEN remoteCode = remoteCode + 1
· IF (remoteCode = 10) THEN remoteCode = 0
RETURN
· GoFore:
·· HIGH 4
·· LOW 3
·· HIGH 5
·· LOW 6
· RETURN
· GoBack:
·· HIGH 3
·· LOW 4
·· HIGH 6
·· LOW 5
· RETURN
· GoForeRight:
·· HIGH 5
·· HIGH 3
·· LOW 6
··· PAUSE 1375·· '1275
·· LOW 5
·· LOW 3
· RETURN
· GoForeLeft:
·· HIGH 4
·· HIGH 6
·· LOW 3
·· LOW 5
··· PAUSE 1575
·· LOW 4
·· LOW 6
· RETURN
· RobotStop:
·· LOW 3
·· LOW 4
·· LOW 5
·· LOW 6
· RETURN
· DriftRight:
·· LOW 4
·· PAUSE 300
· GOSUB GoFore
· RETURN
· DriftLeft:
·· LOW 5
·· PAUSE 300
· GOSUB GoFore
· RETURN
I've only posted the relavent code.
Bean.
What more could I ask for, two different ways to approach the problem. Now I have something to·work with.
*****code
'·· File...... Test1.sxb
'·· Purpose... SX/B Programming Template
'·· Author....·
'·· E-mail....·
'·· Started...
'·· Updated...
' Program Description
' Device Settings
DEVICE········· SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ··········· 4_000_000
' IO Pins
' Constants
' Variables
·led1 var rb.0
·irpin var rc.0
·irpulse var byte
·temp1 var byte
·idx var byte
· INTERRUPT
ISR_Start:
· ' ISR code here
ISR_Exit:
· RETURNINT ' {cycles}································
· PROGRAM Start
' Subroutine Declarations
·ledon sub
·getcode sub
·processcode sub 1
·gofore sub
' Program Code
Start:
do
·ledon·· 'Turn on LED
·getcode
·processcode temp1
·'goto stop
loop
getcode:
pause 1000· 'Turn on LED, to make sure I got here
·ledon
do
·pulsin irpin, 0, irpulse
loop while irpulse < 240 'Does not work with 220
'Get bits
·temp1 = 0···· 'Temp1 is a byte, 8 bits long
·for idx = 1 to 8 'Step through eight times
· temp1 = temp1 >> 1 'Right shift by one
· pulsin irpin, 0, irpulse 'Get the pulse
· if irpulse > 120 then· '1.2 ms = binary 1, 0.6 ms = binary 0
··· temp1 = 1·· 'Store value in bit space· ??
· else
··· temp1 = 0··· 'Store value in bit space ??
· endif
·next· 'Next bit
'irpulse = temp1
'if irpulse < 10 then
'irpulse = irpulse + 1
'endif
'if irpulse = 10 then
'irpulse = 0
'endif
return temp1
processcode:
irpulse = temp1
if irpulse = 16 then· ' If ChUp button was pushed
gofore· 'Turn on the LED
endif
return
ledon:
·tris_b=0
·led1 = 0
·pause 1000
·led1 = 1
return
gofore:
·pause 1000· 'Turn on LED to make sure I got here
ledon
return
stop:
sleep
