Ultimate Sonic Distance
···· Does anyone know the maximin ultra sonic echo in distance, that has
been obtained.
· Short
been obtained.
· Short
All kidding aside, I must assume you mean an off-the-shelf ultrasonic measuring device.· The usual documents are at about 30 inches.·
I think you can get generalized 'shotgun' measurements of motion easily at six feet.
For far reaches, much depends on what you are using for a transducer in terms of power output and how you focus it [noparse][[/noparse]parabollic reflector or resonant tube], but beware that·I have heard tales [noparse][[/noparse]many years ago] of ultrasonic in the form of high power can actually resonante a woman's earnings and make her quite fidgity. I imagine anything that can resonanate to that particulary frequency will respond - maybe your dog, maybe your dental work.
If you are going for high power, you must be aware that there are always potential physical hazards.
Medical ultrasonics supposedly is harmless, but when they looked at my gall stones I felt sore afterwards [noparse][[/noparse]they also use ultrasound to shatter such stones].
Sound responds to the density of the atmosphere and air movements.· So humidity and wind both play havoc with distances, light is so much easier. In medical imagining they take advantage of this, but it requires quite a bit of computerized number crunching and I suspect that it is a multiple phased system.
Post Edited (Kramer) : 11/21/2005 11:04:39 AM GMT
I actualy thought by pulsing a transducer with a high voltage pulse, 20 or 30 feet
might be abtained. On with experimenting.
Thanks Short
Jon Williams
That is a great idea, I saw one in a picture on a Jameco add the whole unit was
very expensive 150 dollars. The senser was a bout 2 inches in diameter compared
to one half inch. Mabey I will find just a element on the web?
Thank you
Short
Jon Williams
for the proper frequency. Simply increasing drive voltage does not necessarily equate to using a bulldozer to get the
job done.
Beau Schwabe
IC Layout Engineer
I suppose that that's one way to get the 100,000th post [noparse]:)[/noparse]
Didn't think you were elegible, though..... 8^)
Truly Understand the Fundamentals and the Path will be so much easier...
I have been spoiled and impatient with the speed.·
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 11/22/2005 8:44:03 PM GMT
Thanks for the insight
Short
I used the IRU-5180, which can sense 1-10ft. The same manual covers the IRU-5280, which can go out to 20ft. It gives you 1024 divisions over the span, which can be defined through the software that comes with it. I had it setup in our shop for testing before it went to the site and was very impressed with the sensitivity and repeatability. Anyway enough talk here is a link to the manual.
http://www.stevenswater.com/catalog/products/water_level_sensors/manual/90841%20Ultrasonic%20iru-5000.pdf
Looks like the IRU-5180 is $795(ouch!) from stevenswater
http://www.stevenswater.com/catalog/product1.aspx?Product_ID=133
We purchased them through:
INC Sales
Vince - Salesman
734-283-6599
It was about the only thing we could find that they would warranty for use with chlorine.
