Im looking for your input on a project Im working on (the Gopher)
Hi all I’m looking for your input on a project I’m working on
I work on industrial laundry equipment one of the jobs we do is clean the lint that builds up in the ducts. I’m trying to get out of carrying the brushes and rods to the roof and then pushing and pulling it up and down from 1 to 6 stories while standing on a pinched roof The desired finished project would be able to climb a duct from inside with either a camera for inspection and or a rotating brush to nock the lint loose
Some things to know most of the ducts I’m working with are round and start at 8” and progressively increase in size roughly 2” for every additional dryer and 2” for every 10’ of rise so it could end up being 36” at the roof with that in mind I built a prototype tractor /gopher that has 3 tracks placed at 180 120 degrees apart and will adjust its with as it climbs currently using vex motors and tracks that I added rubber to for traction but would like to find something better eventually
Now what’s need is the controller to drive the system im thinking the control box would have an analog single direction joystick or pot for forward and reverse speed control a duel joystick for camera pan tilt An LCD display on off switch for the brush with a stamp sending info to a psc in the gopher unit the cameras, LCD and brush motor I currently have are 12Vdc
OK I’M IN OVER MY HEAD AGAIN but im learning something new every day and that’s the main goal of this project any way. where I need your help
Question 1. Where do I find the analog joysticks the type that are used in hobby transmitters I tried google but only found porn sights or video game equipment or is their an better or different way
············· 2. I would like to limit the wires going to the gopher unit if I use 12vdc I would need to regulate it to 5vdc for the psc and 7.2vdc the servos to give me 1, ground 1,12v+ 1,pwm and 1,viedo cable is this the best way?
·············· 3. Does any one know where to find good rubber tracks I found every thing from ones to fit my skid loader to ones for an m1a1 Abrams tank but nothing like what im looking for?
·············· 4. Does any one have source for a good inexpensive color camera and LCD display preferably hard wired I don’t think rf will work with the metal
············· 5.Can i send pwm from the stamp to the psc 60' away?
Thank you for your time all comments good or bad will be very much appreacheated
Brian
There's nothing a good wack with a hammer won't fix
Darn I let the white smoke out again
Post Edited (Washer Medic) : 11/17/2005 4:37:42 AM GMT
Brian
Thanks, Parallax!
1) You can get 2 toggle switches, attach one of them to the other (for a 4 way toggle), sort of like how its dont in hobby RC remotes. Or you could try and disassemble a console game controller-some of the newer ones (PS2,gamecube,xbox) probably use some type of encoding system (if tahts what its called, like using different pulse values to indicate which buttons are pressed, requiring only a few wires for the 20+ different buttons), but older controllers (like those for the sega genesis, maybe supernes) may have a simple 1 wire per button (switch) config, which you can easily just hook up the wires to an extension and to your stamp.
3) If you find any, please post here-I'm sure many are interested in these (at least I am)
4) Ebay. You can probably get a wireless "mini color camera" for $30. Just get a really long AV cable extension to eliminate the "wireless factor." Some camera bundles on Ebay are simply a wired camera plugged into a "video" signal transmitter, so you could just take off the transmitter and plug to an extension. You could use a laptop and USB video adapter for the screen, or maybe a cheap portable DVD player.
5) I believe it depends on the resistance of the wire- you can measure it and find out your current/voltage (im not sure) loss and (I dont know if you could do this but) make up for the loss accordingly.
Just curious-what are you using for a motor controller(s)?
a banded this idea I was afraid some smart allic might have stuck a long screw in the pipe half way up that would either pop the blatter or worse yet get stuck on it
I’ll try to answer some questions as well as ask some more on my current design
Yes the tracks are spring loaded with the current setup I can go from an 8” pipe to a 14”pipe although I’m not satisfied with the wide range of differing tension produced from the springs would like to find a different method that would keep the same tension over a wider range of motion thought about active suspension but that would be later and then theirs the kiss principle to consider also the tracks im using are hard plastic that slip so I coated them with a latex product but it doesn’t last to long now im trying the stuff you dip tool handle’s in it seams to be sticking a lot better although its tough to apply
Currently using RC gear from my helicopter to test the gopher in the 8”fill pipe on the side of a silo but it doesn’t change in size and the RF signal doesn’t work well in the pipe
The VEX motors im using are just continues rotation servos I would have preferred to use the Parallax ones but didn’t know how or where to get gears ect for them and the way the Vex motors attach is handy I have several wire less cameras but I think ill have the same problem with them that I have with the rc gear so I’m looking at wired ones
The learning curve is a lot steeper then I originally imagined I went through the what’s a micro controller text and the concepts I have seam doable but there are a few things I need to understand a whole lot better my first hurdle is sending pwm from the stamp 60’ away to the psc this would control 3 drive motors fwd and reverse from a single joystick or pot pan and tilt from a duel joystick have not decided on the brush motor yet weather its just a continues rotation servo or a rc car motor with controller well back to my research though google is not being very friendly to me right now must not be asking the right questions
·1+1=10
Seems to me like you have two problems that you have to deal with for the moment, 1, how do you get the 'gopher' out, and 2, how do you accomplish a clean transitoning within the duct work. By clean I mean going from 8" to 10" to 12" , ..., 36". Keeping in mind vertical, horizontal, angular, and any other weird configuration.
Post Edited (Rsadeika) : 11/18/2005 7:03:43 PM GMT
Post Edited (SN96) : 11/22/2005 1:43:29 PM GMT
Thanks, Parallax!
... motorized brush/vacuum robot and remote ... video camera that travel through your ... Johnsons Plumbing, Heating and Air ...
www.yeswefixit.com/HVAC/hvac_air_quality.htm
Although I didn't see a picture of the robot on the site , these guys have a robot that cleans duct and makes before and after videos.....maybe if you e-mail em they might share some info.
Paul
the digikey info was very helpful im going to order a few shortly and try them out also I found an old Futaba pre 1990 rc transmitter I had laying around I might cannibalize the joysticks from that in the meantime
Rsadeika
I have little fear if the gopher gets stuck in my past life I was a building contractor in fact I built a few of the building’s we work in now so a little bit of spackle and drywall and its like new. Already had an incident 20’ in with a manual brush and my fiberglass push rod snapped ended up using an old window sash weight and a rope to get it out. Theo destroying a $60 brush wasn’t that bad compared to smashing a $1000 robot OUCH!! also I have other thoughts on how to deal with this the tether could be set up that when you pull it could release tension on the tracks making it easier to retrieve probably will run in to a few problems on the mechanical end but it’s the electronics end I need guidance on to proceed much farther
SN96
Shore will you will probably get tired of seeing me
Jim
I like the magnet idea just might look in to that a little and the education is the true goal I was able to troubleshoot and repair a $1600 proprietary computer board with the training from my Parallax scope
Longneck
Nice site
As for the gopher I’m trying to break every thing down into small systems see enclosed drawing comments and ideas will be appreciated
Brian
Thanks, Parallax!
1. Why build your own joystick when you can go off-the-shelf?· You could use a Sony PlayStation analog controller and get two joysticks (granted, not great resolution) and 16 button inputs -- this would be useful for a robotic controller (in fact, that's the theme of my January N&V article that uses and SX [noparse][[/noparse]programmed in SX/B] to create a serial PSX interface).
2. Probably -- but you'll want to put a lot of filtering onto the 7.2 volt supply for the servos so that motor noise does not get back to the electronics.
3. I have no idea about tracks; you might check with robot clubs like the Dallas Personal Robotics Group (www.dprg.org) or Seattle Robotics Society (www.seattlerobotics.org).
4. Check with BG Micro or similar suppliers -- they carry those things.
5. The PSC takes a serial signal, not PWM; what you may want to do is use and RS-485 connection for distance and noise immunity.
Jon Williams
Since Jon mentioned his new article, pertaining to joy sticks, it came to mind, that in the·Guenther Daubach book, he has an SX tech bot project which uses a joy stick and the SX tech board. The source code in the book is assembly, so that may not be the way you want go. I am not a 'bit banger', not for the SX anyway, but their are other people on the forum that are.
I assume that you have the electronics squared away for the VEX motors, so the next thing is how to control the joy stick for the videocam setup. I think that I remember glancing at a thread on this forum pertaining to somekind of swivel mechanism for just such a thing, I could be wrong, but you may want to do a search, and see if you find something.
At this point you may have to start considering what kind of processor you will be using, for your project, I/O availability may not yet be an issue. If I were you I would keep a close eye on that. If you start relying on a particular processor, and it falls short of expectations, then you may end up with, back to the drawing board.
One other issue that you have mentioned, the track system. I get the impression that you are not getting the necessary tension when you are at, let say 36" duct. Since you already mentioned a bladder system, you may want to investigate electro-pneumatics. It probably will not be an easy search, but you may find something along those lines in some of the specialty robot outfits.
Jon thanks I didn’t mean to interrupt your vacation
I need to get a better understanding of programming the psc the docks just are not doing it for me can you suggest any books or articles that might help and the rs-485 as well I’m thinking I’m in way over my head at the moment but willing to learn just hope everyone has patience with my extreme learning curve
Rsadeika ones and zeros are way over my abilities at the moment though I will be interested in Jon’s joystick article
Unfortunately I don’t have the electronics worked out at the moment I only have concepts on how I think it should go together
The pan tilt mechanics are fairly simple Parallax has them for the hex crawler
Thinking back to my old sewer camera I might not even need it if I get the right camera
I’m hoping I can do everything with a bs2 it won’t be an autonomies vehicle that will need a lot of programming ability just manual control just frying to limit the amount of wires going to gopher by using the stamp and psc
As for the tracks im concerned the vex tracks will not hold up they only snap together the traction has not bin a problem yet but won’t know until I get the electronics worked out and get a chance to test it better
Thanks again for all the help I’ll be away for the holiday going to visit Mom in Florida but will be back to the project next week
Brian
As for RS-485, it's not that complicated -- check out Jan Axelson's book "Serial Port Complete."
Jon Williams
well first hurdle Rc time reading a pot on the joystick. Yes it would probably be better to use the play station joystick as Jon recommended but I’m trying to use an old Futaba joystick it fits in my controller panel better. The pot on the Futaba joystick is marked 5 k referring back to the what’s a microcontroller text chapter 5 they use a 10k pot I would think that would not be a problem all I need to do is change the scaling is this correct.
Using the exercise ReadPotWithRcTime.bs2 on page 151 I ended up with a hi # of 209 and a lo # of 142 verses the 10k pot that has a hi # of 691 and a lo of 1 my question is using the formula’s on page 155 I get the fractional value of 418 but I don’t seam to be getting the proper servo rotation what am I doing wrong
thank you Brian
