DC motor speed control
· hi·
···· my project in school is to control a dc motor speed and take the
·····feedback from motor to microcontroller (BS2) and display on computer
···· the speed at which the motor is rotating .
····· i am facing difficult in finding a model·for this and i want a lowcost
····· model.it would be good if some one having the code and the parts
······ description can help me in this regard
······· hope to hear some thing good
Set up your STAMP to control a drive motor. This doesn't need to be a big motor, but ideally bigger than the following one.
Take another DC, Permanent Magnet motor (like the small hobby motors) and using belts, gears, or even an o-ring or rubber band, have your drive motor also drive this motor. This motor then becomes a generator, and the faster it turns, the higher the output voltage will be. This can be a very small motor.
Using and A/D (Analog to Digital) converter, you can take the output from the second motor, and use this as your feedback.
For a really "neat" experiment, you might want to disaply the voltage and current (Amps or milliamps) that the drive motor is using, and also have a way (possibly as simple as a clothespin you can squeeze to increase the friction on the shaft) to apply a variable load to the drive motor.
What this doesn't do, at lease without extra work, is provide any direct feedback on what the actual RPM is, but if you had access to some type of tachometer, you could calibrate the output of the generator.
Another more direct method might be to attach a small magnet to the shaft, gear or something on the drive shaft of your drive motor, and then use a Hall Effect sensor to count the revolutions. This would eliminate the need for the second motor. Parallax has a Hall Effect sensor at: http://www.parallax.com/detail.asp?product_id=605-00005
The same thing could be done with a dark (or light) stripe and a light sensor.
John R.
8 + 8 = 10
·i want the information regarding the pulse width modulation chip i can
·use for varying and controlling the motor , let me know the lowcost chip
please
waiting for ur reply
bye
I am using a propeller and i was thinking of mounting the chip just behind the spinning prop
If there is light in the room it should pick up a frequency of the pulsing light
by painting the back of the prop white and using a white LED next to the chip it could pick up reflected light
But I don't have one yet but it might work.
http://www.parallax.com/detail.asp?product_id=27924
To use it as any kind of absolute speed sensor, you'd either have to isolate it from ambient light or calibrate it every time you moved it.
You need to shut off the voltage going to the motor for a few milliseconds, measure the voltage of the still spinning motor.
I suppose an NPN PNP Transistor setup could give you a switch that switches off one circuit and switches the other on.
So if you are pulsing the mortor with PWM, you can read the voltage it produces during the OFF time of the PWM.
Cool ea...
Thanks, Parallax!
fan
5 volt very small computer fan
simple solution for speed control
transistor with "PWM". most DC motors controlled this way now
simple solution for "RPM" Called Optisensor used like hall effect
led, photoresistor, aperture, a/d converter. the frequency of high voltage to return would be your Varible
or a hall effects sensor
small amount of parts
simple solution
japer
by placing a low value resistor in parallel with the coil.
From here you can read a pulse as the motor is powered by setting up a simple current
monitor ( series resistor to measure voltage across) and a DC blocking filter (capacitor).
One drawback is that you can not use PWM. Instead you can use an adjustable linear
voltage regulator ( with a digital potentiometer perhaps) to regulate motor speed.
Beau Schwabe
IC Layout Engineer
