Simple SX48 Question
After flipping through the datasheet and a quick forum post search I cant find the answer to this, of course it may be because its an obvious question... The SX48 has 4 sets of VDD/VSS lines, are these there for ease of routing or are they there to distribute the load between different areas of the micro controler? Should they all be connected to VDD/VSS?
A very good question indeed.
Without being an expert on the subject, my perspective on it is:
I believe the pins are connected together on the die with multple bonding wires, one each per pin. These wires tend to be very light gauge, and hence will have voltage drop on them according to the current flowing in each. So it would behoove one to use the mutiple sets in parallel FOR SUPPLYING THE PROCESSOR ONLY.
Definitely NOT for convenience of routing power/ground to other areas of the board.
Running multiple lines of less power per line also somewhat lowers the emitted EMI because the lines are separated a bit from each other.
Cheers,
Peter (pjv)
·Yes, that was my question exactly. I wouldnt dare to try and pull power from them. Convenience meaning you could supply power from whatever side it happened to be on in a board layout. Just curious if all 4 sets are needed to get full current supply to the processor? Oh and making all 4 on a single sided board involves actually wiring them in so I'm trying to avoid that. [noparse]:)[/noparse]
Chris Savage
Parallax Tech Support
csavage@parallax.com
Greetings from Germany,
G
·1+1=10
Chris
