A guide on bypass capacitors
Time to time someone asks in the forums what values should be used for bypass capacitors, with the answer that it is a little bit of a black art. EDN has a new article out that discusses the issue and provides formulas for expected di/dt switching noise and the minimum value capacitor required to counteract it, the article is located here. One word of warning though, to fully understand the article you'll need to know a little theory, but they present formulas that can be used by any general hobbyist who understands basic algebraic formulas.
If anyone wants a copy of any of the IEEE articles suggusted in the "Read more about it" box, let me know and I'll get a copy of it for you, I have access to the entire IEEE and ACM databases.
·1+1=10
·1+1=10
Chris Savage
Parallax Tech Support
csavage@parallax.com
Sad to say, I came across a comment the The Art of Electronics that mentioned the combination of a ceramic and tanatanlun intended to filter can actually create a parasitic oscillator due to the inductances in the radial leads.
This is an area where 'tweak' is the best solution and in order to do so I suspect you have to have an O-scope watching the effects of change. I also suppose it is why everything has gone to SMS as the clock frequency has climbed. If it is slow, you have less worries.
I must say that some of it is marketing exploiting imagined ills [noparse][[/noparse]like the doctor telling you to eat more fiber]. More filters usually can't hurt. But, then there is that parasitic oscillator to ponder. Hmmmm........
