How to speed up the dc motor via BS2?
presently, i build a small surveillance robot with use of parallax basic stamp 2 microcontroller, when i plug my dc motor to it, i found that not enough faster the rotation of motor, got any idea to boost it up?
i suppose to modify the programming or add on a additional circuit?
·· How is it you're connecting the motor to the BASIC Stamp?
Chris Savage
Parallax Tech Support
csavage@parallax.com
Thanks, Parallax!
Please do not run this in this configuration any longer!· Also, you aren't giving 6V out of the BASIC Stamp if you're putting 6V into it.· It's a 5V unit, so it's outputs are 5V, but at no more than 25 mA.· You will need a transistor to drive you motor at the very least!
Chris Savage
Thanks, Parallax!
http://www.parallax.com/detail.asp?product_id=30052
Chris Savage
can i use this H-bridge to operate my motor, if can..somebody can teach me wat is the source code that i going to use?
Post Edited (lgz108) : 11/12/2005 4:39:33 AM GMT
Thanks, Parallax!
As with all H-bridges of this type, it is very important that R and L do not BOTH go high at the same time.
Doing so will let the smoke out of your H-Bridge. You can easily prevent this "accidental" situation with a
simple Opto-isolator configuration that I mention in the link below.
http://forums.parallax.com/showthread.php?p=525862
Beau Schwabe
IC Layout Engineer
