is there a way to tag threads for future reference? and other similar questions
In trying to research my spontaneous-mysterious-refusal-to-download-to- BS1 problem, I·have scanned 2000 threads, so far. I'm only halfway through,· and· I'm starting to wish I'd taken notes, because now I only sorta remember where the similar threads·were....·how do you handle this?·If I wanted to assemble a help-file relating to a problem, is there a better way than downloading the threads and working them on my PC? Can you even do that?
Could there be a standard set of subjects created, so that searching would be reliable?
· -Eric
· -Eric
It is my experience that "Standardized" subjects will create more problems than they solve, even if used a "secondary" marker. People will forget to set them, interpret them differently than one another, and not change them as a subject evolves from one to another. Even with the relatively broad descriptions of the differnt forums here, it seems there are regulary topics being moved from one forum to another (appropriately so).
I believe, based on hints, that the all powerful and knowledgeable IT Guy at Parallax is working on enhanced searching capabilities. The fact that they let this guy out of the back room to answer posts here is a testiment to the trust they (Parallax) have in him, and his ability to talk with users without alienating them. If we give him time, he will fix it. Just don't expect him to do it in his "free time", as he has none. If he is married, he has less than none.
Speaking as another IT guy, search capabilities in general are a pain in the -ah-er- neck to get working the way people want. There are outfits that make a substantial living providing search engines and services, and the fact that there are numerous companies offering numerous options should be a good clue that nobody, not even Google, has found "Search Utopia" yet.
Lastly, and possibly most significantly, if you see a thread you like, you can either save a reference to the page as a bookmark (Ctrl-D in most browsers) or cut and past the URL from the address bar into another document for future reference. This is probably better than "downloading", as it gets you back to the thread itself, including any updates since your original visit.
John R.
8 + 8 = 10
· -Eric
Jim
Parallax IT Dept.
· -Eric
Our long term plans for threads are to keep them on-line for as long as the hardware can keep up with the message volume. The site has been up for about 17 months and we're still a long, long way for pushing the underlying hardware.
Jim
Parallax IT Dept.
I've certainly no idea if this is doable with your present software (dotnettBB), so just consider it a passing thought. If messages "aged out" (say) after 18-24 months or so, at back-up time, and then became compressed, so marked, and then rejoined the message base, I don't think anyone would complain about the subsequent decompresion time to retrieve them.
I suppose this might necessitate a newest-to-oldest search mechanism, to avoid constantly running into compressed messages, but I'm not sure message age or order is as important as the contents of the message itself.
Bruce Bates
Using some sort of near storage solution is a good way to keep the working set to posts to a manageable size. The site was designed to have sufficient capacity to avoid any archive operations for years. At design time, it we determined that it was less expensive and more effective to throw hardware at the problem instead of radically changing the undelying dotNetbb code. the good news is that, over time, the hardware keeps getting bigger, faster and less expensive. I can't say the same for coders [noparse]:)[/noparse]
Jim
Parallax IT Dept.
Truly Understand the Fundamentals and the Path will be so much easier...
Most threads, it appears to me, had good advice, but given randomly, as well-meaning people happened to think of things which might help. Since searching is probably a lost cause, couldnt the KB at least have articles about what to do if you get certain specific error-messages? I tried to educate myself before (or at least along with) bothering others with my problem, but got no help at all from the KB. Wouldnt it be a time-saver to write one article such as "what to check when your stamp wont downoad," listing "batteries, cables, port-settings, buffers, ... " etc, and point people to it, versus trying to remember all those things again & again? I would help write it myself, but dont know anything. Maybe a KB organized like a wiki (I think I'm using this right) would facilitate the institutional memory...
· -Eric
·· This is something we're already working on.
Chris Savage
Parallax Tech Support
csavage@parallax.com
