Question on interfacing GP2D12 with the BASIC Stamp 1 Project Board
Hi there, I am an industrial design college student and am trying to use the sharp GP2D12 IR sensors to give me an analog responce through my serial port in ascii format so I can use some software I am working on to read the ascii and use it to control a function on the computer. So basically I need to know if I can use the BASIC Stamp 1 Project Board, and what would the code look like to give my pc ascii code from the sharp GP2D12 IR sensors. Thanks for all the help for I am new to this and any diagrams and such will help.
·· You would need an Analog To Digital Converter (ADC).· As for the values, remember that this sensor is non-linear in it's output, and so will be your data.· On the other hand, if you use the BASIC Stamp 2, we have a ready-made program to read this, and all you would need would be the ADC0831 chip.
Chris Savage
Parallax Tech Support
csavage@parallax.com
http://www.parallax.com/dl/docs/cols/nv/vol5/col/nv114.pdf
As for a BS1 example, we don't currently have one available.· You'd simply have to work through it.
Chris Savage
