One of my servos goes crazy!
I wrote a simple program(see code below) so i could enter a 3 digit number (string) into the debug window, which corresponds to the PWM value i want for my servo. It's supposed to ask the user "Enter a 3-digit number: " and wait for 3 characters to be entered. It then prints the value entered, and moves the servo to the corresponding position, and then cycles to the while loop again (prompting for the next value), However, with this certain servo, it doesn't wait for any characters to be entered-it continues by itself. After every other second the servo goes from one extreme to another (left and right, etc), and i see the "Enter a 3-digit number: " show up each time, although i never get the chance to enter any numbers before it cycles through the while loop again.
import stamp.core.*;
public class servoValueTester
public static int value;
public static StringBuffer buff;
public static PWM pulse;
public static void main()
pulse = new PWM(CPU.pin15,173,2304);
while(true)
buff=new StringBuffer();
System.out.println("Enter 3 digit number: ");
buff.append(Terminal.getChar());
value=Integer.parseInt(buff.toString());
System.out.println("V1alue entered : " + value);
pulse.update(value,2304);
Here is what messages show up in the debug window with other servos:
280V1alue entered : 280
080V1alue entered : 80
173V1alue entered : 173
With this particular servo:
Is there anything that's wrong with my code? Or is my servo bad? It's a blue bird high torque servo. When i had it on a RC reciever, i noticed it was more sensitive than other servos (larger range of travel vs same input). Any input on this issue would greatly be appreciated, thanks.
while(true)
Insert this line
System.out,println("Program start\n");
as the first statement in main()
If this line is printed every time then you know the javelin
resets because it is outside the while loop and
should be printed only once.
If the javelin resets, try running the servos from a
seperate power supply. Connect the servo power ground
to the javelin power ground.
regards peter
edit:
I also noted you create a new stringbuffer inside the while loop.
This will eventually run you out of memory.
define
static StringBuffer buff = new StringBuffer();
and in your while loop
buff.clear();
The same applies to
because a temporary string is created that is used only once.
Change it to
System.out.print("Value entered : ");
System.out.println(value);
Post Edited (Peter Verkaik) : 11/5/2005 8:17:24 AM GMT
Thanks for the tips on printing strings. I'm used to programming with no regard for use of memory, so these tips will sure help in the future.
