Serstring
I have an array:
ser VAR byte(8)
I tried to declare
Tag1 var ser(0)
but that didn't work.· How do I declare tag1 = ser(0) without using additional RAM bytes.
Sid
ser VAR byte(8)
I tried to declare
Tag1 var ser(0)
Sid
tag0 VAR byte
ser VAR tag0 ' alias name
tag1 VAR byte
tag2 VAR byte
tag3 VAR byte
tag4 VAR byte
tag5 VAR byte
tag6 VAR byte
tag7 VAR byte
Now you can refer to ser() as if you had defined the array explicitly.
ser(0) is the same as tag0
ser(7) is the same as tag7
and so on.
Tracy Allen
www.emesystems.com
Sid
