Javelin Terminal Window Help — Parallax Forums
Sabre3487Sabre3487 Posts: 16
edited 2005-11-01 18:58 in General Discussion
Can anyone explain how I can get simple integer data back from the debug terminal window?
In BS it is easily done.· I can't seem to do it with JAvelin.
·char inputs = Terminal.getChar();
·int data = (int)inputs;
· I want·a simple user input back from the terminal.· They enter a numeric number and then I perform some math functions on that number.
· It seems that when I get the data I can not cast it back or get it to the numeric value I want to use.
· 3 = 51(ascii number)··Just want the int 3!
Scott·
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2005-11-01 11:52
    First get my adapted Terminal class (Terminal.java) here:
    (rename your Terminal.java to Terminal.org) then copy my Terminal.java to the core folder.
    http://groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/stamp/core/
    Then get my Format class (Format.java) here:
    http://groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/stamp/util/text/
    There is also a pdf file for the Format class.
    Complete Format application package with demo programs (Appnote 012):
    http://www.parallax.com/javelin/applications.asp
    char[noparse]/noparse line = new char[noparse][[/noparse]7]; //allows up to 6 chars (decimal 16bit number with sign)
    int[noparse]/noparse i = new int[noparse][[/noparse]1]; //placeholder for binary int
    Terminal.getString(line,6); //read up to 6 chars from terminal
    Format.bscanf(line,0," %d",i); //read int value skipping any leading whitespace
    Now i[noparse][[/noparse]0] is the binary value you entered via Terminal.
    Read the pdf file for more·info on bscanf.
    regards peter
    Post Edited (Peter Verkaik) : 11/1/2005 12:07:01 PM GMT
  • Sabre3487Sabre3487 Posts: 16
    edited 2005-11-01 16:57
    Thanks alot.
    I was started writing my own last night thinking that is what·I had to do.· I wondered why though that the Basic Stamp debug window had all of this in there and not the javelin.
    edited 2005-11-01 17:50
    The basic stamp is an other microcontroller and exists longer than the javelin.
    Look around the files section on yahoo group JavelinCode.
    Most code I have put there are general utilities, because the Javelin
    lacked those. The Format class is very useful for user interface code
    using the IDE message window, or for printing to char arrays.
    regards peter
    edited 2005-11-01 17:56
    I am getting an error with the Format command
    ·Format.bscanf(line,0," %d",value);·· <--- says either misplaced or not found????· and the Format.java file is in the
    edited 2005-11-01 18:03
    The Format.java must be placed into
    %javelin_ide_path%\stamp\util\text folder.
    If that folder does not exist, create it first.
    In your main class
    import stamp.util.text.*;
    then you can use
    Format.printf("just some text\n"); //same as System.out("just some text\n");
    Format.printf("a hex value %04x",value); //print hex number with leading 0's to message window
    Format.bscanf(line,0," %d",i); //read a binary int
    etc.
    regards peter
    edited 2005-11-01 18:27
    That took care of it.· I did not have the text folder, went to parallax and redownloaded the whole app zip file.
    I also had to look more closely at the bscanf parameters I was not accepting an int [noparse]/noparse back in.· I appreciate all of your help.
    bscanf() is very handy for multiple parameters on a single line.
    For example, if you input values for x, y and z via terminal, you
    just enter the values seperated by spaces, on a single line.
    In your code
    char[noparse]/noparse line = new char[noparse][[/noparse]81];
    int[noparse]/noparse x = new int[noparse][[/noparse]1];
    int[noparse]/noparse y = new int[noparse][[/noparse]1];
    int[noparse]/noparse z = new int[noparse][[/noparse]1];
    int k; //parser index
    Terminal.getString(line,80); //single line holding multiple values
    k = Format.bscanf(line,0," %d",x); //parse x
    k = Format.bscanf(line,k," %d",y); //parse y
    k = Format.bscanf(line,k," %d",z); //parse z
    In the same way you can use bprintf() to assemble a string into a char array
    without the overhead of String methods (the Format class does not use Strings,
    although it accepts Strings in formal parameters)
    regards peter
