Serial Interface "Key" for BS2
Does anyone know of an existing circuit board that has all of the Serial Interface components that interface to the Stamp 2 Interpreter Chip.· I would like my project to only have the Interpreter Chip, EEPROM, and Resonator (and a capacitor).· I would like to have all of the Serial Interfacing components on a "Key" that would plug in via .1" posts (like the SX-Key).
This will provide a cost savings over the long term, since I can buy the Interpreter, EEPROM and Resonator for $20 compared to the OEM price of $45 (yes, I know that there is currently a special on OEM's for $30 now).· I will likely buy an OEM to get the components and "first set" of Interpreter, EEPROM and Resonator.· Then it will be a $10 savings each time I do a Stamp project. (or $25 savings if they are no·longer on sale).
I do not consider the votage regulator as part of the Stamp since I am considering the voltage regulator as part of the rest of the project cost.
I can't easily prototype my own since the DB-9 connector does not fit into standard .1 spacing on a typical protoboard.
Any ideas?·
Any ideas?·
Jon Williams
·· What about USB2SER?
http://www.parallax.com/detail.asp?product_id=28024
Chris Savage
Parallax Tech Support
csavage@parallax.com
You might consider using a tool like ExpressPCB to make the custom board. If you can fit it onto their standard board size you can get three for $51 -- I think this is a deal versus point-to-point wiring. Check them out: www.expresspcb.com. BTW...if you do go the ExpressPCB route, be sure you start with a schematic; once it checks out the PCB layout program will help you connect one component to another.
Jon Williams
Jon - have you had any experience with Sparkfun's Circuit Board services? http://www.sparkfun.com/shop/index.php?shop=1&cart=449123&cat=86& at $5/sq in, it will only cost me $10.00 at most!
Have you tried this site the price is quite reasonable for DTE/DCE RS232/TTL cards...
www.hvwtech.com/products_list.asp?CatID=163&SubCatID=197&SubSubCatID=198
Bob N9LVU
This is exactly what I was thinking about! Which one do I buy to connect my PC Serial port to the Stamp Interpreter chip? The DTE or the DCE? I will ask HVW as well, but wondered if you had any specific experience with this.
You probably want the DCE version, with sockets (aka female), as this will let you plug your PC into the adapter with a 'straight through' RS-232 cable. Note on your module you'll have to 'loop' pin 6 to pin 7.
Note you'll have to connect DTR through the module to the 'ATN' signal of the PIC in order to reset it for programming. I'm not sure what the circuit should be there -- look at the schematic of the BOE or OEM for more pointers.
Jon Williams
