BS2e Help lost code
I am working on a project.· I am a vol firemen and i am trying to use hte BS2e to be my flash pack for my leds that i am making.· My only problem is that i had wrote some code for the BS2e and my hd crashed and lost the code i need to some how get it from the stamp.· I also need to figure out how to have one have a mometary swith on it so when i hit it it changes flash patterns.· Any help would be great.· I wrote most of the code in binary so i could flash more than one pin at a time.· Is there and easier way?
thanks
mike
Jon Williams
mike
Reset:
· DIRA = %1111
Main:
· FOR OUTA = %0000 TO %1111
··· PAUSE 1000
· NEXT
· GOTO Main
This displays binary values, %0000 to %1111 on P0..P3, with a one-second delay between changes.· If this isn't what you're looking for then you'll have to be much more SPECIFIC, going so far as to spelling out the sequence you want, e.g.,
1 - 0000
2 - 1001
3 - 0110
-- back to #1
As far as different ways to flash the LEDs, I suggested StampWorks earlier because it has an excellent example (even if I do say so myself) of presenting different patterns on LEDs.
Jon Williams
Post Edited (Jon Williams (Parallax)) : 10/27/2005 4:43:02 AM GMT
I dont know what the command was bfore the binary
%0000000001
I think had something here not sure
%0000000010
basicly what ineed to do is i am trying to make flash patterns for these leds i have made for my car. so i will need to lets say flash pin 0 and pin 2 at the same time then flip to pin 1 and to pin 3. I dont knowif you are familer with strobe patterns on a police car. I am basicly making whats on the police cars and fire trucks. I jsut need to make the flash back with the BS2e
' {$STAMP BS2} ' {$PBASIC 2.5} Led1 PIN 0 ' Led1 Led2 PIN 1 ' Led2 Led3 PIN 2 ' Led3 Led4 PIN 3 ' Led4 Main: DO LOW Led2 'turns Led2 off LOW Led4 'turns Led4 off HIGH Led1 'turns Led1 on HIGH Led3 'turns Led3 on PAUSE 2000 ' waits 2 seconds HIGH Led2 'turns Led2 on HIGH Led4 'turns Led4 on LOW Led1 'turns Led1 off LOW Led3 'turns Led3 off PAUSE 2000 ' waits 2 seconds LOOP 'repeats untill BS2 is turned off.This is about as simple as it gets.
Post Edited (BPM) : 10/27/2005 5:21:39 AM GMT
Jon Williams
thanks
mike
Jon Williams
I am new to it all as you cant tell
thanks
mike
Jon Williams
thanks
mike
http://www.parallax.com/detail.asp?product_id=28123
Jon Williams
thank you
FLASH:
HIGH 0
PAUSE 500
LOW 0
PAUSE 500
HIGH 2
PAUSE 500
LOW 2
HIGH 1
PAUSE 500
LOW 1
HIGH 3
PAUSE 500
LOW 3
IF IN5 = 0 THEN FLASH:
IF IN5 = 1 THEN DOUBLE:
Double:
HIGH 0
PAUSE 800
LOW 0
PAUSE 500
HIGH 2
PAUSE 800
LOW 2
HIGH 1
PAUSE 800
LOW 1
HIGH 3
PAUSE 800
LOW 3
IF IN5 = 0 THEN DOUBLE:
IF IN5 = 1 THEN TRIPLE:
Triple:
Yes, the best way to start understanding the stamp, is to hook it up and try it out.
Definetly read the WAM... I would do that first before trying to program the BS2
