Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
power adpter ? for the boe-bot — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
lobo
100
2005-10-26 22:01
edited 2005-10-26 22:18
in
BASIC Stamp
can i use a output:6v 2000ma power adapter to power up the boe-bot with the basic stamp 2?
allanlane5
3,815
2005-10-26 22:06
edited 2005-10-26 22:06
Yes, you should be able to. I assume it has the standard 'barrel' connector (5.5mm/2.1mm), with center positive.
lobo
100
2005-10-26 22:18
thanks
Sign In
Register
to comment.
