Adc0831
I can't seem to find a usable schematic for the ADC0831. Could someone please give me or point me in the direction of a good schematic?
RoboGeek
There are 10 kinds of people in the world,
those that know binary and those that don't.
Formerly bugg.
www.goldmine-elec.com
www.parallax.com
www.expresspcb.com
www.startrek.com
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
Jon Williams
Try this
http://www.parallax.com/dl/docs/books/sw/exp/sw27.pdf
Ken
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
Rafael
For the 1298 you are limited to 9v when using a 9v source, and the same limitation can be overcome with a voltage divider.
If a voltage divider is the way you decide to go, I would run either ADC off 5v to keep the power supply topology simple. Also, I would make sure the divider current is at least 10 times the current required by the ADC, 1 mA should be plenty.
Ken
·· I recently checked out a link posted by a forum member which showed where a guy used a very interesting method of measuring 0-15V with a BASIC Stamp and a 5V ADC.· He piped the voltage (Via resistor) into an Optocoupler, then read the output into the ADC.· Not sure about linearity or accuracy, but it seemed to work well in the application which was measuring the voltage levels of Car Batteries in-system.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Hopefully this will cut some time out of trial and error...
·· I saved the link at home, so I will post it in a couple of hours for you.·
Chris Savage
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
Post Edited (RoboGeek) : 10/24/2005 7:35:10 PM GMT
Jon Williams
I'm using it in a voltage divider like this:
Vdd--thermistor--ADC input pin--1k resistor--Gnd.
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
RoboGeek
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
The car battery voltage monitor can be found at the following link:
http://genki.home.ionet.net/BattMon/BattMonArticle.html
Chris Savage
Jon Williams
Formerly bugg.
www.parallax.com
www.expresspcb.com
www.startrek.com
Ken
Jon Williams
