SX external storage
What chip should I use for external storage for an SX microcontroller? The SX has to write to it and read from it.
All my exes live in Texas
Oh yeah, all my exes are six feet under the ground!!!
One was a lineman who violated the one hand rule.
The·second put his tongue on 10 car batteries wired in series.
The third was involved in a tesla coil experiment gone bad.
·1+1=10
Jon Williams
Fast serial speeds, max speed is upwards of 15-25 mbps
uses only a few pins (parallel memory can eat pins like crazy)
non-volatile w/ no battery backup
easy to write to in SX/B or asm
Largest capacity is about 32k bytes, but you can use multiple chips in parallel all sharing a bus
http://www.ramtron.com/doc/Products/serial.asp
I'm using one of the FM25256 in a project right now at about 7mbps and it works perfectly.
Keith
