quick help writing a real short program for a sharp 120 object detector
the sharp is on pin 15 and using a lm339, basic stamp 2 on the boe-bot and servos are connected to port 12,13. i would like the debug to remain just so when boe is connected i can see or verify the the sensor are working. what can i do to cause the servo to react when the sensor sees something? I just need something quick and basic for i am a beginner. thank you.
according to the 123 project for the evil genius
'IR Proximity Dectector-Monitor Sharp GD2D120 Proximity Detector Output
'{$STAMP BS2}
' {$PBASIC 2.5}
' IR Proximity Detector - Monitor Sharp GD2D120 Proximity Detector OUTPUT
'Variables
Whisker PIN 15
Flag··· VAR Bit
' Initialization
·Flag=0
· DO
··· IF (Whisker = 0 ) AND (Flag = 0) THEN
····· Flag = 1: DEBUG "Ouch, collision",
··CR
····· ELSE
··· ' When Whisker Released, Reset
······· IF (Whisker = 1) THEN Flag = 0
······· ENDIF
······· LOOP
'{$STAMP BS2}
' {$PBASIC 2.5}
'Variables
Whisker PIN 15
Flag··· VAR Bit
' Initialization
·Flag=0
· DO
··CR
····· ELSE
······· ENDIF
······· LOOP
'IR Proximity Dectector-Monitor Sharp GD2D120 Proximity Detector Output '{$STAMP BS2} ' {$PBASIC 2.5} ' IR Proximity Detector - Monitor Sharp GD2D120 Proximity Detector OUTPUT 'Variables Whisker PIN 15 Flag VAR Bit position VAR Word direction VAR Byte ' 0=home, 1=count up, 2= count down pHOME VAR Word ' Home position of servo pMAX VAR Word ' Maximum value of position pMIN VAR Word ' Minimum value of position ' Initialization Flag=0 phome=750 pmax=1000 pmin=500 position=phome direction=0 DO IF flag=1 THEN 'Whisker is on IF direction=1 THEN position=position+10 'Count up IF position>pmax THEN 'Check boundrys position=pmax direction=2 'Reverse direction ENDIF ENDIF IF direction=2 THEN position=position-10 'Count Down IF position<pmin THEN 'Check boundry position=pmin direction=1 'Reverse direction ENDIF ENDIF ENDIF IF direction=0 THEN 'If wisker is off IF position>phome THEN position=position-1 'Return slowly to home position IF position<phome THEN position=position+1 ENDIF DEBUG DEC position , CR PULSOUT 14,position 'Talk to servo PAUSE 20 'Alternet code if you use a clock could be here 'Sending a pulsout only every 20ms instead of waiting 'Would allow more processing to be done IF (Whisker = 0 ) AND (Flag = 0) THEN Flag = 1 DEBUG "Ouch, collision",CR direction=1 ELSE IF (Whisker = 1) THEN ' When Whisker Released, Reset Flag = 0 direction=0 ENDIF ENDIF LOOP
