Electrical Noise Problem
I have a circuit that uses three 74LS273 flip flop·chips.· They store a logic state captured from the data bits on the PC's parallel port.· The control bits on the parallel port control the clock for the flip flop.· I have a noise problem with the flourescent light above my workbench plugged into the same outlet.· When I switch it on it somehow sends a clock pulse to the flip flops and captures·the parallal port data when·its not supposed to.· When·you switch the flourescent light off·the flip flop captures garbage data.· What can I do to stop this?· I am using a filtered·voltage regulated power supply to power the flip flops.· The power supply uses a transformer and full wave bridge rectifier before the regulator and capacitors.
thank you···
thank you···
Chris Savage
Parallax Tech Support
csavage@parallax.com
Post Edited (kingneb) : 10/10/2005 8:22:15 PM GMT
Chris Savage
If youput the device in a plastic food box [noparse][[/noparse]for electrical insulation] and then wrap the whole box in aluminum foil, you may eliminate the problem.
Ground the Aluminum foil to your computer's chassis.
Obviously, this is only a test solution.
Once you are sure that you have eliminated the problem, you need to provide a similar metal chassis as a permanent solution.
If the problem still exists, it is in the cabling or power supply transients.
Try a battery to observe if the power supply is or is not the problelm. A battery inside the box won't create transients. There are several remedies for power supply problems.
If cables are the problem, you can wrap them in aluminum foil for a trial. Then later go to shielded cables.
G. Herzog in Taiwan
Post Edited (Kramer) : 10/12/2005 8:22:07 AM GMT
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
I have a PCB with a large (10A) relay-and-mosfet high current controller I built. Now the board is big and still has a lot of space, so I thought I'd add more stuff like my LCD controller. I also thought to mount a chip socket for my Stamp. What kind of electrical noise problems can I expect if I have diodes across the relay coils, power everything off the same power supply (exept the logic part goes through a 7805) and as yet use no caps anywhere? How can I prevent it? Where would I have to strategically place my caps?
Please remember I am 15 and may have trouble with elaborate filtering schemes.
Rafael
Sometimes it's best not to worry about everything until you have to!!
Not that you shouldn't take some precautions when designing circuits....but I don't think you should build too much protection in to something that you may not need to protect from....
So....polarity protection on power supplies is a great thing....however, putting coupling capacitors and ferrites and such everywhere, although may help, may also just give headaches....
Anyhow, noise from relays comes in a couple forms. You have the foldback of the electric field around the relays coil....when it's de-energized, it can feed back in to your stamp and play the gremlin...the diode pretty well kills this. You can also have issues with the mechanical motion of the relay....if you are running high currents (hopefully through an appropriately rated relay) you get arcs across the contacts as it's about to make full contact (you sometimes get contact bounce which causes more arcing)....this can give some greif...but you really have to have some sensitive stuff in your circuit to be of worry.
I'd say, build it first and then go back and deal with noise. Follow datasheets directions if they are asking for capacitors across power leads near their devices....
If you still want to take the precautions....post your schematic and let us red ink it!
Steve
Anyway, I'll go on and see what happens.
Rafael
Thanks for the help
All my exes live in Texas
Oh yeah, all my exes are six feet under the ground!!!
If you're working with RF....or expect to work in an RF environment....having short leads is important as well as many other things...but depends on what your running (and you're not yet willing to say!
Steve
If you have a single sided board, you can always mount a second board to it as a backing and connect a ground wire to it.
You might use plastic standoffs or plastic screws to put the two together if you cannot find enough convienent places to drill holes.
Thank you
One was a lineman who violated the one hand rule.
The·second put his tongue on 10 car batteries wired in series.
The third was involved in a tesla coil experiment gone bad.
Post Edited (kingneb) : 10/17/2005 1:12:01 AM GMT
On the train transformer [noparse][[/noparse]at the noise source], you can use a computer protection circuit - there are two components a spike arrestor and a low pass noise filter.
I have one of the low-pass noise filters in a metal enclosue with two lines in, two lines out, and a ground. I am guess that it will block both ways as its schematic appears sysmetrical.
Try a temporary battery supply. Also, some of the larger breadboards have a ground-able backplane.
I am very interested in your progress as I am trying to build several projects.
It wouldn't hurt to put another one on the SX's power line.
Both should be part of a shielded case, so the CORCOMs that fit into a hole in the case seem most appealing. [noparse][[/noparse]this assures that the power line going into the case doesn't manage to go around the protection.
The Art of Electronics confirms that they are excellent to stop noise in AND OUT. The spike arrestors may be unnecessary, but won't hurt.
Post Edited (kingneb) : 10/19/2005 7:58:49 PM GMT
Steve
