BOE-BOT with BS2SX?? NEED HELP!!
the basic set of boe-bot has the BS2 in it, but i changed into BS2SX
but then most codes in the reference book that came with the boe-bot kit.
so what should i try to make this happen?
i did try to change some pulsout and freqout into the different setting, but it did not work
i looked through the command reference, and i found out there is some differencies in units in period, maximum pulse width (PULSOUT), and units in period and units in freq1, freq2 (FREQOUT) between BS2 and BS2SX
i changed the pulsout according to the differencies in units in period
like [noparse][[/noparse]BS2] 650 x 2 = [noparse][[/noparse]BS2SX] NEW PULSOUT x 0.8
[noparse][[/noparse]BS2] 850 x 2 = [noparse][[/noparse]BS2SX] NEW PULSOUT x 0.8
DEBUG "running"
counter VAR WORD
FREQOUT 4, 2000, 3000
FOR counter = 1 TO 64
PULSOUT 13, 850
PULSOUT 12, 650
DEBUG "forward"
PAUSE 20
NEXT
PAUSE 200
FOR counter = 1 TO 24
PULSOUT 13, 650
PULSOUT 12, 650
DEBUG "make turn"
PAUSE 20
NEXT
PAUSE 200
DEBUG "backward"
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
NEXT
END
this is the basic code for the BS2 chip according to the reference book
then how should i change the pulsout and the freqout to make it works
DEBUG "running"
counter VAR WORD
PULSOUT 13, 850
PULSOUT 12, 650
DEBUG "forward"
PAUSE 20
NEXT
PAUSE 200
PULSOUT 13, 650
PULSOUT 12, 650
DEBUG "make turn"
PAUSE 20
NEXT
PAUSE 200
DEBUG "backward"
PULSOUT 13, 650
PULSOUT 12, 850
PAUSE 20
NEXT
END
The BS2sx is 2.5 times faster than BS2. For PULSOUT on the BOE-BOT·that makes center on a servo with a BS2sx is 1875 (750 on BS2 x 2.5). Likewise 1250 inplace of 750 and 2500 in place of 1000. For FREQOUT· units on BS2 (1 unit represesnts 1 HZ) and on the BS2sx (1 unit represents 2.5 HZ). Therefore FREQOUT units on the BS2sx are equal to·BS2 units divided by 2.5
I hope this will help
······ Joe Fishback
-Robots are my friends-
that really helped
