Serial com, reading one line at a time
Hey guys,
Got a javelin here and I am using it to communcate with a modem via AT commands. Problem is·when using the Hypertermcom example I send a command, get back the result but if I call my routine to send the command and check the result again I get the first command. I am pretty sure this is due to the javelins internal buffer(from what I have read) but I am not sure the easiest way to approach. I have looked at Peter's Uart additions and noticed he has a clear buffer command. I was thinking of maybe using it to clear the buffer after every command sent to prevent this but I would like peoples opinions if there is a better way. Preferably I would like to get to the point that I would just read one line at a time and once the line is read I dont have to worry about it any more.
Best regards,
Drew
Post Edited (Acidshock) : 10/17/2005 1:55:57 AM GMT
Best regards,
Drew
import stamp.core.*;
public class MDMCOM {
//Com Port
final static int SERIAL_TX_PIN = CPU.pin0; //DB9 2
final static int SERIAL_RTS_PIN = CPU.pin1; //DB9 7
final static int SERIAL_CTS_PIN = CPU.pin2; //DB9 8
final static int SERIAL_RX_PIN = CPU.pin3; //DB9 3
//Set pins directly for now for testing purposes
static Uart txUart = new Uart( Uart.dirTransmit, CPU.pin0, Uart.dontInvert, Uart.speed9600, Uart.stop1 );
static Uart rxUart = new Uart( Uart.dirReceive, CPU.pin3, Uart.dontInvert, Uart.speed9600, Uart.stop1 );
static StringBuffer buffer = new StringBuffer(120);
static char c;
static void bufferMessage(){
while (c != '\r'){
if(rxUart.byteAvailable()){
c = (char)rxUart.receiveByte();
buffer.append(c);
public static void main(){
System.out.print("Testing program\n\r");
buffer.clear();
txUart.sendString("AT\r");
bufferMessage();
System.out.print(buffer.toString());
buffer.clear();
txUart.sendString("AT+CREG\r");
bufferMessage();
if(buffer.toString() == "ERROR")
System.out.print("\nError found!\n\r");
else
from the uart buffer and returned by the call. So you don't need to clear the uart buffer.
You can't send an AT command to hyperterminal. If you open a com port in hyperterminal
that connects to the javelin, there is no way hyperterminal can relay any received command
to a modem. You should connect a modem (via level shifter like max232) to the javelin.
Most modems require more than just tx and rx signals.
You then can visualize the modem<->javelin communication by System.out.print() calls.
regards peter
I know I cant send AT commands to Hyperterm, just been using it to simulate my interaction with the device(sO I can see exactly what both sides are sending and receiving) Now I have the device hooked up and the device still doesnt clear the buffer, I am having to manually clear it via your addon. You mentioned byteReceive() however I am not seeing that anywhere in the Uart.java file. I do see receiveByte do you mean that by chance? I am currently using that but for some reason every time I use that method it does not seem to remove it. Here is the current function I am using to extract the data. Its working for me at the moment but its rather dirty and I much rather a cleaner solution.
//bufferMessage:
//This function will parse the internal Uart buffer and feed it into a string buffer
//named "buffer."
//The first value of the function is how long to wait until parsing the buffer.
//The second value is what line of the receive buffer you want to start at.
static void bufferMessage(int time, int startline)
buffer.clear();
int currentline = 1;
CPU.delay(time);
while (rxUart.byteAvailable() == true){
if(startline > currentline)
if(c == '\r' || c == '\n')
currentline++;
else
if(currentline > (startline+1))
buffer.append(c);
else
currentline++;
else
buffer.append(c);
rxUart.bufferClear();
