"Javelin not found on serial port"
Ok, to cut to the chase, I'm using a brand new javelin stamp and super carrier, with a usb-serial adaptor. I'm pretty sure I have the right COM port and that the adapter works, because it gives me a different error message if I specify another COM port. All I have done is opened the javelin stamp package, put it onto the IC socket (yes, its the right way), plugged in a new 9V battery (led lights up, stamp warms up), hooked up the cable, written and successfully compiled "helloworld," and clicked "debug," only to get the "not found" message. I've done almost everything the manual suggests, except trying it on a different computer. Is there anything I've missed or done wrong so far? ALso, how do I know if I have a "null modem adaptor? All mine says is "USB to RS232 cable," so could this be what's wrong? Any help would be greatly appreciated, thanks.
Edit: I've tested my stamp with another computer with a serial port, and it worked great. I've also tried reintalling/downloading more recent drivers for my cable, but none seem to work
. Looks like I need a new cable.
Post Edited (bulkhead) : 10/16/2005 6:07:50 AM GMT
. Looks like I need a new cable.Post Edited (bulkhead) : 10/16/2005 6:07:50 AM GMT
http://forums.parallax.com/showthread.php?p=543933
(edit)
(other things to try, Copied from other treads)
to use a wall-mount power supply
you may need to set the "Latency timer" to one. Go to your "Device manager" and click on ports, then click on the "Port settings" tab and then click on "Advance" and you see the "Latency" timer setting, change it to one.
And, if by change your adapter has a listing for a FIFO buffer (Unlikely) disable it.
You will probably have to restart your computer for the settings to take effect.
Post Edited (diafysal) : 10/15/2005 3:39:57 PM GMT
I gave up on my USB to parallel port a long time ago....
I tried everything recommended for this problem and could not get it to work under any circumstances.
